After upgrading to 2023.6.3 everything time I try to check configuration or restart homeassistant I receive the following error “Failed to restart Home Assistant ‘cast’”
Same here.
Any solution?
Apparantly our problems are not noticed.
How do we make it noticed? My system is running on a raspberry Pi and have it running since the beginning and have continullaly updated my system finally upgrading to Portainer after many attempts to update my original system. Now I have the same issues with updates not happening. It is appararant they want us to move to the latested which I don’t really care about the newest options!!
In my case I had to remove the Cast: configuration from my config file. Appears to be a new way to prompt people to cleanup depreciated configuration items.
I’m coming from about 6 months since the last update so i had a few, TTS base url prevented restart shortly after.
Yes that worked for me also after I realized cast was in the configuration.yaml file. Thanks for your input!!
After I removed cast from my configuration.yaml file my problem was solved.
