Failed to set state, fall back to unknown
Hello!
I can not find where is the problem of this log… Where I can to dig?
Logger: homeassistant.helpers.entity
Source: helpers/entity.py:906
First occurred: 09:24:12 (12 occurrences)
Last logged: 09:24:15
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 906, in _async_write_ha_state
    hass.states.async_set(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1687, in async_set
    state = State(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1264, in __init__
    validate_state(state)
  File "/usr/src/homeassistant/homeassistant/core.py", line 184, in validate_state
    raise InvalidStateError(
homeassistant.exceptions.InvalidStateError: Invalid state with length 381. State max length is 255 characters.
Which one of your sensors or input_texts has an unknown state?
Look in Developer Tools → States.
There is a lot of them…
Entity State Attributes
Filter entities Filter states
lock.1_st_dusa_grida_child_lock
1.st duša grīda Child lock|unknown|
|lock.2_st_vannasistaba_grida_child_lock
  1. st vannasistaba grīda Child lock|unknown|
    |number.1_st_dusa_grida_min_temperature_limit
1.st duša grīda Min temperature limit|unknown|
|number.1_stava_koridora_grida_min_temperature_limit
  1. stāva koridora grīda Min temperature limit|unknown|
    |number.2_st_vannasistaba_grida_min_temperature_limit
  2. st vannasistaba grīda Min temperature limit|unknown|
    |number.viesistaba_grida_min_temperature_limit
Viesistaba grīda Min temperature limit|unknown|
|person.ingus
Ingus|unknown|
|select.terase_2_color_power_on_behavior
Terase 2 Color power on behavior|unknown|
|select.terase_4_color_power_on_behavior
Terase 4 Color power on behavior|unknown|
|select.terase_6_color_power_on_behavior
Terase 6 Color power on behavior|unknown|
|select.terase_7_color_power_on_behavior
Terase 7 Color power on behavior|unknown|
|sensor.1_st_dusa_grida_program|unknown|
|sensor.1_stava_koridora_grida_program|unknown|
|sensor.2_st_vannasistaba_grida_program|unknown|
|sensor.aquarea_metered_backup_heater_power_consumption
Aquarea Metered Backup Heater Power Consumption|unknown|
|sensor.aquarea_metered_backup_heater_power_consumption_total
Aquarea Metered Backup Heater Power Consumption Total|unknown|
|sensor.aquarea_metered_power_consumption
Aquarea Metered Power Consumption|unknown|
|sensor.aquarea_metered_power_consumption_total
Aquarea Metered Power Consumption Total|unknown|
|sensor.foxess_energy_generated_compensation
sensor Compensation|unknown|
|sensor.inventors_total_kwh_compensation_4
|sensor.openweathermap_dew_point
OpenWeatherMap Dew Point|unknown|
|sensor.openweathermap_forecast_temperature_low
OpenWeatherMap Forecast Temperature Low|unknown|
|sensor.openweathermap_uv_index
OpenWeatherMap UV Index|unknown|
|sensor.panasonic_heat_pump_1wire
HeishaMon detected 1wire sensors|unknown|
|sensor.panasonic_heat_pump_main_heat_pump_model
Aquarea Heatpump model|Unknown model for HeishaMon|
|sensor.panasonic_heat_pump_s0_watt
HeishaMon detected s0 sensors|unknown|
|sensor.panasonic_heat_pump_stats_5
HeishaMon bad CRC reads|unknown|
|sensor.panasonic_heat_pump_stats_8
HeishaMon too long reads|unknown|
|sensor.samsung_clp_360_series_tray_tray_1
Samsung CLP-360 Series Tray tray_1|unknown|
|sensor.viesistaba_grida_program|unknown|
|sensor.virtuve_grida_program|unknown|
|switch.darba_istaba_radiators_valve_detection
Darba istaba radiators Valve detection|unknown|
|switch.haralda_darba_istaba_1_radiators_valve_detection
Haralda darba istaba 1.radiators Valve detection|unknown|
|switch.haralda_darba_istaba_2_radiators_valve_detection
Haralda darba istaba 2.radiators Valve detection|unknown|
|switch.haralda_darba_istaba_3_radiators_valve_detection
Haralda darba istaba 3.radiators Valve detection|unknown|
|switch.haralda_gulamistaba_radiators_valve_detection
Haralda guļamistaba radiators Valve detection|unknown|
|switch.kapnes_valve_detection
Kāpnes Valve detection|unknown|
You can ignore everything except sensors without a unit_of_measurement. i.e. only consider text based sensors.
Also you should not have that many unknown devices in your config.
I disabled or edited all of this sensors, and problem is solve!
Thanks!
