Failed to setup remote access
Hi! I have setup my Duck DNS plugin like this:
lets_encrypt:
  accept_terms: true
  certfile: fullchain.pem
  keyfile: privkey.pem
token: <my token>
domains:
  - <my subdomain>.duckdns.org
aliases: []
seconds: 300
And my configuration.yaml:
http:
    ssl_certificate: /ssl/fullchain.pem
    ssl_key: /ssl/privkey.pem
    ip_ban_enabled: true
    login_attempts_threshold: 5
homeassistant:
  internal_url: https://<local address of Pi>:8123
  external_url: https://<my subdomain>.duckdns.org:8123
My setup in router is this (the internal IP is reserved for Pi):
So, my address in Duck DNS starts with 188 and it is the same with IP on thewhatismypublicip.com, so it is not “Gray” and it is correct, but I still can’t gain access by going to:
on my phone via cellular connection.
Your HA instance listens on port 8123:
homeassistant:
  internal_url: https://<local address of Pi>:**8123**
  external_url: https://<my subdomain>.duckdns.org:**8123**
Obviously you have to port forward to port 8123 but not to port 80 and/or 443.
Should I setup in my router new forward for:
  • external: 443
  • internal: 8123?
    I have this setup previously, but it didn’t work. I will do it again, if this one is correct. And should I just add this one or remove previous forward rules?
Most important is the forwarding to the internal port. For external you can either also set 8123 or from “whichever”**port.
**whichever means: all ports, not explicitly port 443!
This setup doesn’t give me access to https://.duckdns.org
This one also doesn’t work.
No disrespect, but are you sure you have the knowledge to open (potential security relevant) ports / settings in your router? :slight_smile: Just saying…
You need to set the incoming ports (called external port) 443 and 8123 as a port forward to the same ports on your HA server.
External port 443 → 192.168.0.105 → Internal port 443
External port 8213 → 192.168.0.105 → Internal port 8123
Port 443 is for letsencrypt and 8123 is for HA. So to call HA you should use https://mydomain.duckdns.org:8123
Isn’t it the same with my pre-previous message? And I also tried to enter address with port number.
My configuration is a bit simpler but I struggled with it for hours before deleting the ‘/’ characters in front of ssl/… filenames for certificate & key.
   # Example configuration.yaml entry for the HTTP component
 http:
    ssl_certificate: ssl/fullchain.pem
    ssl_key: ssl/privkey.pem
I just forward 443 → 8123 and 8123 → 8123
my.duckdns.org without a port number works both internally and externally.
I have struggled with this too and read a lot of different confusing advice.
With DuckDNS & LE I’m using:
default_config:
  external_url: "https://mysubdomain.duckdns.org"
  internal_url: "http://ip-of-HA:8123"
In my modem/router I have only forwarded 443 external to internal.
@vchkhr: this is a helpful guide Remote access for Home Assistant
