Hello, Forum users
I installed hass.io on my Synology NAS 920+ through the package center.
And after installation, Mosquitto broker on supervisor tap but it can’t start. Popup message is below.
500 Server Error for http+docker://localhost/v1.39/containers/f287dec4cd768bdfef61372ed32848cf3cea5a50cb6e5bc33486454673b010fa/start: Internal Server Error (“OCI runtime create failed: container_linux.go:345: starting container process caused “exec: “/dev/init”: stat /dev/init: no such file or directory”: unknown”)
On the docker, there is a container of Mosquitto broker so I think installation is done but it stopped and i can’t start as well.
Start container addon_core_mosquitto failed: {“message”:“OCI runtime create failed: container_linux.go:345: starting container process caused “exec: \”/dev/init\”: stat /dev/init: no such file or directory": unknown"}.
I just recovered Core to 2021.1.5. But it still not working. Maybe the problem with Supervisor. It shows the current version as 2021.02.3.
Have no idea how to roll it back
I think it’s not hass.io version issue and file system as well. Because i had test 3 old versions and changed the file system format from btrfs to ext4. I always delete everything such as docker, images, HA and repeat the installation. However, i can see the same error. Finally, i want to have test different docker versions but i don’t have .apk file. Please give me a solution if somebody have it.
I found a workaround.
The cause is the supervisor version
Open your terminal.(DSM - Docker - Container - Hassio_cli - terminal)
Type “ha supervisor update --version=2021.01.7”
then your supervisor version will be changed(2021.02.3 > 2021.01.7)
Finish!!(끝!!)
So sad,when i try to restart zhe addon,still not working on 2021.02.5,so i change the supervisor version to 2021.01.7,zhe Mosquitto works,but my NODE RED is missing in the addon store with error.That`s drives me crazy.
Actually this makes me sad. I’ve created a full snapshot of a properly working system and then did the update today to the newest versions. Goal was to get Z2M update to 1.17.1. After the update, I got the same error shown above, just concerning z2m.
Then I restored the snapshot (restore everything) I’ve created some hours ago and the error is still the same. So creating snapshots turns out as completely useless? What do I need this feature for, if not for exactly this?
400 Client Error for http+docker://localhost/v1.39/containers/cbf43a204a1d4e8e139244589988fd4c3f5f569dfee361030d428cca57e758a5/start: Bad Request ("OCI runtime create failed: container_linux.go:345: starting container process caused "exec: \"/dev/init\": stat /dev/init: no such file or directory": unknown")
I update hassio to the last version and found this problem, I restore the snapshot in 2021.2.2 (esphome worked fine) but now doesn’t work. Can anybody help me?
Actually works for me only if restored to 2021.01.7.
If I upgrade back to 2021.02.5 or newer, error 500 comes back :(.
Hope we will have a solution in the near future for an up to date Docker by Synology :).
Thanks BlueJay for the solution for the meanwhile.
Just one point, when I switched to 2021.01.7, all addons were deleted.
Snapshot restore does not bring these back, although these are running inside the docker.
Any solution to this issue? Or just re-install all add-ons in the supervisor?
