After updating Z-Wave JS UI the integration fails to restart. A reload from a previous backup does not work. A restart does not work.
Here is a section of the log;
2023-01-25 15:50:59.790 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
Error: getaddrinfo ENOTFOUND core-mosquitto
at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:107:26)
2023-01-25 15:50:59.793 INFO MQTT: MQTT client closed
2023-01-25 15:51:02.796 INFO MQTT: MQTT client reconnecting
2023-01-25 15:51:02.804 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
2023-01-25 15:51:02.806 INFO MQTT: MQTT client closed
2023-01-25 15:51:05.809 INFO MQTT: MQTT client reconnecting
2023-01-25 15:51:09.537 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
2023-01-25 15:51:09.539 INFO MQTT: MQTT client closed
2023-01-25 15:51:12.541 INFO MQTT: MQTT client reconnecting
2023-01-25 15:51:12.549 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
2023-01-25 15:51:12.551 INFO MQTT: MQTT client closed
2023-01-25 15:51:15.555 INFO MQTT: MQTT client reconnecting
2023-01-25 15:51:19.290 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
2023-01-25 15:51:19.293 INFO MQTT: MQTT client closed
2023-01-25 15:51:22.297 INFO MQTT: MQTT client reconnecting
2023-01-25 15:51:22.309 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
2023-01-25 15:51:22.313 INFO MQTT: MQTT client closed
2023-01-25 15:51:25.316 INFO MQTT: MQTT client reconnecting
2023-01-25 15:51:29.038 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
2023-01-25 15:51:29.040 INFO MQTT: MQTT client closed
2023-01-25 15:51:32.043 INFO MQTT: MQTT client reconnecting
2023-01-25 15:51:32.054 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
2023-01-25 15:51:32.058 INFO MQTT: MQTT client closed
2023-01-25 15:51:35.061 INFO MQTT: MQTT client reconnecting
2023-01-25 15:51:38.791 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
2023-01-25 15:51:38.797 INFO MQTT: MQTT client closed
2023-01-25 15:51:41.798 INFO MQTT: MQTT client reconnecting
2023-01-25 15:51:41.807 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
2023-01-25 15:51:41.810 INFO MQTT: MQTT client closed
2023-01-25 15:51:44.811 INFO MQTT: MQTT client reconnecting
2023-01-25 15:51:48.539 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
2023-01-25 15:51:48.541 INFO MQTT: MQTT client closed
2023-01-25 15:51:51.545 INFO MQTT: MQTT client reconnecting
2023-01-25 15:51:51.555 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
2023-01-25 15:51:51.557 INFO MQTT: MQTT client closed
2023-01-25 15:51:54.560 INFO MQTT: MQTT client reconnecting
2023-01-25 15:51:58.290 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
2023-01-25 15:51:58.294 INFO MQTT: MQTT client closed
2023-01-25 15:52:01.296 INFO MQTT: MQTT client reconnecting
2023-01-25 15:52:01.303 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
2023-01-25 15:52:01.305 INFO MQTT: MQTT client closed
2023-01-25 15:52:04.309 INFO MQTT: MQTT client reconnecting
2023-01-25 15:52:08.040 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
2023-01-25 15:52:08.044 INFO MQTT: MQTT client closed
2023-01-25 15:52:11.045 INFO MQTT: MQTT client reconnecting
2023-01-25 15:52:11.055 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
2023-01-25 15:52:11.058 INFO MQTT: MQTT client closed
2023-01-25 15:52:12.797 INFO APP: GET /health/zwave 200 2.795 ms - 2005
2023-01-25 15:52:14.060 INFO MQTT: MQTT client reconnecting
2023-01-25 15:52:17.789 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
2023-01-25 15:52:17.792 INFO MQTT: MQTT client closed
2023-01-25 15:52:20.795 INFO MQTT: MQTT client reconnecting
2023-01-25 15:52:20.804 ERROR MQTT: Mqtt client error getaddrinfo ENOTFOUND core-mosquitto
2023-01-25 15:52:20.806 INFO MQTT: MQTT client closed
2023-01-25 15:52:23.810 INFO MQTT: MQTT client reconnecting
I use an Aeotec Z-Stick Gen5+ that has been working fine for months. The dongle is plugged into a Raspberry Pi 4. This has happened before after an update. Unplugging the dongle briefly seemed to solve the issue before. Not this time
It’s not finding your MQTT server, Did you enable MQTT deliberately?
