fluefiske
(André Van Stijn)
February 28, 2018, 7:06pm
1
Good evening,
I have an automation which i tried to made a little more simple but now it is not turning off the light every time, what did I do wrong.
- service: homeassistant.turn_on
entity_id: switch.fibaro_system_fgs223_double_relay_switch
alias: Garageverlichting aan
- entity_id: sensor.aeotec_zw100_multisensor_6_burglar
platform: state
to: '8'
- action:
- service: homeassistant.turn_off
alias: Garageverlichting uit
platform: state
to: '0'
for:
minutes: 1
Thanks in advance,
André
tom_l
February 28, 2018, 9:36pm
2
The way it is configured the sensor has to see continuous movement for 1 minute to trigger the automation. Is this what you wanted and is it actually happening?
fluefiske
(André Van Stijn)
March 1, 2018, 6:08am
3
No Tom, I would like it to turn off the light after the sensor status become 0
fluefiske
(André Van Stijn)
March 1, 2018, 6:40am
4
Hey Tom,
i have the same issue with this automation:
- action:
entity_id: switch.fibaro_system_fgwpef_wall_plug_gen5_switch
initial_state: true
- entity_id: sun.sun
platform: state
to: below_horizon
- action:
platform: time
at: '22:30:00'
Can it be related to the fact that I merged two automations to one and that both id’s are in the automations?
tom_l
March 1, 2018, 2:58pm
5
I thought the id was only used for the automation editor. It certainly wouldn’t hurt to comment out the duplicate or change it and see if that helps.
More importantly your aliases are the same. I think that’s bad. Change them so there are no duplicates.
Also I think aliases with spaces in the name should be in single quotes.
Someone may correct me if I am wrong, still learning this myself.
fluefiske
(André Van Stijn)
March 2, 2018, 7:54am
6
Thank you Tom for your effort. I will try and let you know.
fluefiske:
Your ID’s inside automations.yaml must be unique for every automation. You have used the same id: ‘1518782294120’ more than once.
Simply change at least 1 digit (and make sure that the id isn’t used elsewhere), and you should be fine.
fluefiske
(André Van Stijn)
March 4, 2018, 6:39am
8
It worked, feeling such a noob
fluefiske
(André Van Stijn)
March 4, 2018, 6:40am
9
Finally it works, thanks a lot
