Hi. I successfully installed RaspberryMatic and now I’m trying to install Homematic(IP) Local integration, but I’m getting the error “Failed to Connect” when I submit the configuration data.
The log only gives a unusefull message with no description:
Logger: hahomematic.central
Source: custom_components/homematicip_local/control_unit.py:747
Integration: Homematic(IP) Local ([documentation](https://github.com/danielperna84/custom_homematic), [issues](https://github.com/danielperna84/hahomematic/issues))
First occurred: 13:56:16 (2 occurrences)
Last logged: 13:57:17
I already have setted the firewall configuration in Raspberrymatic to the less secure possible (“Ports Open” and Full Access) and even with this configuration I have tried to add ports mentioned here to the Opening ports list and I have tried to add Ips from my LAN to the “IP addresses for restricted access” and even the IP I think HA is using internally to comunicate with RaspberryMatic (as ifconfig shows)
I even have tried to change the hostname of RaspberryMatic with the IP that nslookup gives me (172.30.33.0)
But nothing works, always the same error and the same log error.
I only have obtained different log error when I change the hostname to the one that Raspberrymatic shows in its GUI, in that case I obtain a “destination host unreachable” as expected. And I obtained a different error too when I uncheck all the checkboxes in “Configure the interfaces to CCU”, in that case, the connection fails again but no error is logged at all.
I have no RF interfaces connected yet (neither USB nor GPIO one, I’m waiting them) so I’m wondering if the connection is failing just because I don’t already have the hardware interfaces connected…
Any ideas?
