I have a problem with hassfest that I’m hoping someone can help me with please. I’m the author of the visonic alarm custom integration here. After finding the instruction here to add the integration_type to the manifest file, this causes the hassfest action to fail
Validating supported_brands... done in 0.00s
Validating translations... done in 0.00s
Validating usb... done in 0.00s
Validating zeroconf... done in 0.00s
File "/usr/local/lib/python3.10/runpy.py", line 196, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/local/lib/python3.10/runpy.py", line 86, in _run_code
exec(code, run_globals)
File "/usr/src/homeassistant/script/hassfest/__main__.py", line 237, in <module>
sys.exit(main())
File "/usr/src/homeassistant/script/hassfest/__main__.py", line 164, in main
plugin.validate(integrations, config)
File "/usr/src/homeassistant/script/hassfest/config_flow.py", line 187, in validate
config.cache["config_flow"] = content = _generate_and_validate(integrations, config)
File "/usr/src/homeassistant/script/hassfest/config_flow.py", line 89, in _generate_and_validate
domains[integration.integration_type].append(domain)
KeyError: 'hub'
Validating config_flow...
Error: Process completed with exit code 1.
My hassfest action passes without the integration_type
line in the manifest.
My hassfest file is copied from here
I’m not knowlegable in this area and any help would be apppreciated, my manifest file is on the above github link but here it is to save you looking it up
"domain": "visonic",
"name": "Visonic Intruder Alarm",
"integration_type": "hub",
"version": "0.8.2.2",
"config_flow": true,
"documentation": "https://github.com/davesmeghead/visonic/wiki",
"issue_tracker": "https://github.com/davesmeghead/visonic/issues",
"dependencies": [],
"codeowners": ["@davesmeghead"],
"requirements": ["pyserial_asyncio==0.4"],
"iot_class": "local_push"
