I have been running dev containers on Linux for quite a while now, building some extensions and even submitting a few patches. I followed the instructions on that page and life was great.
Last night code updated itself and today everything is broken. I cleaned all the docker images, and downgraded the environment but I cannot rebuild it.
Alwys the same error
error: failed to solve: process "/bin/bash -o pipefail -c pip3 install -r requirements.txt --use-deprecated=legacy-resolver" did not complete successfully: unable to find user root: invalid argument
I would appreciate any help and getting it back to work
Full log is below if this helps
[28 ms] Dev Containers 0.262.3 in VS Code 1.74.3 (97dec172d3256f8ca4bfb2143f3f76b503ca0534).
[27 ms] Start: Resolving Remote
[35 ms] Start: Check Docker is running
[35 ms] Start: Run: docker version --format {{.Server.APIVersion}}
[82 ms] Server API version: 1.42
[84 ms] Start: Run: docker volume ls -q
[133 ms] Start: Run: docker build -f /tmp/vsch-jfparis/bootstrap-image/0.262.3/bootstrap.Dockerfile -t vsc-volume-bootstrap /tmp/vsch-jfparis/bootstrap-image/0.262.3
[+] Building 0.2s (9/9) FINISHED
=> [internal] load build definition from bootstrap.Dockerfile 0.0s
=> => transferring dockerfile: 324B 0.0s
=> [internal] load .dockerignore 0.0s
=> => transferring context: 2B 0.0s
=> [internal] load metadata for mcr.microsoft.com/devcontainers/base:0-a 0.2s
=> [1/4] FROM mcr.microsoft.com/devcontainers/base:0-alpine-3.16@sha256: 0.0s
=> [internal] load build context 0.0s
=> => transferring context: 5.90kB 0.0s
=> CACHED [2/4] RUN apk add --no-cache nodejs python3 npm make g++ 0.0s
=> CACHED [3/4] RUN cd && npm i node-pty 0.0s
=> CACHED [4/4] COPY .vscode-remote-containers /root/.vscode-remote-cont 0.0s
=> exporting to image 0.0s
=> => exporting layers 0.0s
=> => writing image sha256:b84159cba79f2a4ab7a697f1f85d89a11f2a084648153 0.0s
=> => naming to docker.io/library/vsc-volume-bootstrap 0.0s
[483 ms] Cloning Github repository: jfparis/core into /workspaces/core
[483 ms] Start: Run: docker run -d --mount type=volume,src=core-baa6bbc339a19ee8eb6de6eb83e60123,dst=/workspaces -v /var/run/docker.sock:/var/run/docker.sock vsc-volume-bootstrap sleep infinity
[791 ms] Start: Run in container: /bin/sh
[796 ms] Start: Launching Dev Containers helper.
[796 ms] ssh-agent: SSH_AUTH_SOCK in container (/tmp/vscode-ssh-auth-5741ac0fd2705d65119a1135a39caec25282ef78.sock) forwarded to local host (/run/user/1000/keyring/ssh).
[797 ms] Start: Run: gpgconf --list-dir agent-extra-socket
[800 ms] /run/user/1000/gnupg/S.gpg-agent.extra
[800 ms]
[800 ms] Start: Run in container: gpgconf --list-dir agent-socket
[906 ms] /root/.gnupg/S.gpg-agent
[906 ms]
[906 ms] Start: Run in container: gpgconf --list-dir homedir
[907 ms] /root/.gnupg
[907 ms]
[907 ms] Start: Run in container: ls '/root/.gnupg/private-keys-v1.d' 2>/dev/null
[908 ms]
[909 ms]
[909 ms] Exit code 2
[909 ms] Start: Run in container: mkdir -p -m 700 '/root/.gnupg'
[909 ms] Start: Run in container: /bin/sh
[912 ms] Start: Run in container: echo ~
[913 ms]
[913 ms]
[913 ms] Start: Run: gpgconf --list-dir homedir
[915 ms] /home/jfparis/.gnupg
[915 ms]
[916 ms] Start: Run in container: gpgconf --list-dir homedir
[916 ms] /root/.gnupg
[916 ms]
[933 ms] Start: Run in container: # Test for /root/.gnupg/pubring.gpg and gpg
[935 ms]
[935 ms]
[935 ms] Start: Run in container: # Copy /home/jfparis/.gnupg/pubring.gpg to /root/.gnupg/pubring.gpg
[968 ms]
[968 ms]
[969 ms] Start: Run in container: # Test for /root/.gnupg/trustdb.gpg and gpg
[970 ms]
[970 ms]
[970 ms] Start: Run in container: # Copy /home/jfparis/.gnupg/trustdb.gpg to /root/.gnupg/trustdb.gpg
[986 ms]
[986 ms]
[987 ms] Start: Run: gpg-connect-agent updatestartuptty /bye
[996 ms] /root
[996 ms]
[996 ms] Start: Run in container: cat <<'EOF-/tmp/vscode-remote-containers-5741ac0fd2705d65119a1135a39caec25282ef78.js' >/tmp/vscode-remote-containers-5741ac0fd2705d65119a1135a39caec25282ef78.js
[997 ms]
[997 ms]
[998 ms] Start: Run in container: cat <<'EOF-/tmp/vscode-remote-containers-server-5741ac0fd2705d65119a1135a39caec25282ef78.js' >/tmp/vscode-remote-containers-server-5741ac0fd2705d65119a1135a39caec25282ef78.js_1675421349786
[1000 ms]
[1000 ms]
[1002 ms] Start: Run in container: # Test for /root/.gitconfig and git
[1003 ms]
[1003 ms]
[1003 ms] Start: Run in container: # Copy /home/jfparis/.gitconfig to /root/.gitconfig
[1005 ms]
[1005 ms]
[1005 ms] Start: Run in container: command -v git >/dev/null 2>&1 && git config --global --replace-all credential.helper '!f() { node /tmp/vscode-remote-containers-5741ac0fd2705d65119a1135a39caec25282ef78.js $*; }; f' || true
[1006 ms]
[1006 ms]
[1006 ms] Start: Run in container: # Test for /root/.ssh/known_hosts and ssh
[1007 ms]
[1007 ms]
[1007 ms] Start: Run in container: # Copy /home/jfparis/.ssh/known_hosts to /root/.ssh/known_hosts
[1009 ms]
[1009 ms]
[1050 ms] Start: Run in container: cat /workspaces/core/.devcontainer/devcontainer.json 2>/dev/null
[1052 ms] Start: Run in container: cat /workspaces/core/.devcontainer/devcontainer.json 2>/dev/null
[1054 ms] Start: Run in container: cat <<'EOF-/tmp/devcontainer-64089032-dba1-4800-877f-fa8b96386d89.json' >/tmp/devcontainer-64089032-dba1-4800-877f-fa8b96386d89.json_1675421349842
[1056 ms]
[1056 ms]
[1056 ms] Start: Run in container: docker volume ls -q
[1423 ms] Start: Run in container: docker ps -q -a --filter label=vsch.local.repository=https://github.com/jfparis/core --filter label=vsch.local.repository.volume=core-baa6bbc339a19ee8eb6de6eb83e60123 --filter label=vsch.local.repository.folder=core --filter label=vsch.quality=stable
[1535 ms] Start: Run in container: docker ps -q -a --filter label=vsch.local.repository=https://github.com/jfparis/core --filter label=vsch.local.repository.volume=core-baa6bbc339a19ee8eb6de6eb83e60123 --filter label=vsch.local.repository.folder=core
[1883 ms] Start: Run in container: node /root/.vscode-remote-containers/dist/dev-containers-cli-0.262.3/dist/spec-node/devContainersSpecCLI.js up --workspace-folder /workspaces/core --workspace-mount-consistency cached --id-label vsch.local.repository=https://github.com/jfparis/core --id-label vsch.local.repository.volume=core-baa6bbc339a19ee8eb6de6eb83e60123 --id-label vsch.local.repository.folder=core --log-level debug --log-format json --config /workspaces/core/.devcontainer/devcontainer.json --override-config /tmp/devcontainer-64089032-dba1-4800-877f-fa8b96386d89.json --default-user-env-probe loginInteractiveShell --mount type=volume,source=core-baa6bbc339a19ee8eb6de6eb83e60123,target=/workspaces,external=true --mount type=volume,source=vscode,target=/vscode,external=true --skip-post-create --update-remote-user-uid-default off --mount-workspace-git-root true
[2193 ms] (node:132) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
[2194 ms] (Use `node --trace-deprecation ...` to show where the warning was created)
[2195 ms] @devcontainers/cli 0.23.2. Node.js v16.17.1. linux 5.15.0-58-generic x64.
[2195 ms] Start: Run: docker buildx version
[2245 ms] github.com/docker/buildx v0.8.2 6224def4dd2c3d347eee19db595348c50d7cb491
[2245 ms]
[2245 ms] Start: Resolving Remote
[2248 ms] Start: Run: git rev-parse --show-cdup
[2251 ms] Start: Run: docker ps -q -a --filter label=vsch.local.repository=https://github.com/jfparis/core --filter label=vsch.local.repository.volume=core-baa6bbc339a19ee8eb6de6eb83e60123 --filter label=vsch.local.repository.folder=core
[2269 ms] Start: Run: docker inspect --type image mcr.microsoft.com/vscode/devcontainers/python:0-3.10
[2287 ms] local container features stored at: /root/.vscode-remote-containers/dist/dev-containers-cli-0.262.3/dist/node_modules/vscode-dev-containers/container-features
[2288 ms] Start: Run: tar --no-same-owner -x -f -
[2309 ms] Start: Run: docker buildx build --load --build-arg BUILDKIT_INLINE_CACHE=1 -f /tmp/devcontainercli-root/container-features/0.23.2-1675421351075/Dockerfile-with-features -t vsc-core-a3326b3531d3eb2709cdfe792550e3f2 --target dev_containers_target_stage --build-arg _DEV_CONTAINERS_BASE_IMAGE=dev_container_auto_added_stage_label /workspaces/core
[+] Building 0.1s (18/21)
=> => transferring context: 227B 0.0s
=> [internal] load build definition from Dockerfile-with-features 0.0s
=> => transferring dockerfile: 4.57kB 0.0s
=> [internal] load metadata for mcr.microsoft.com/vscode/devcontainers/p 0.0s
=> [dev_container_auto_added_stage_label 1/17] FROM mcr.microsoft.com/v 0.0s
=> => transferring context: 6.55kB 0.0s
=> CACHED [dev_container_auto_added_stage_label 2/17] RUN pipx uninstal 0.0s
=> CACHED [dev_container_auto_added_stage_label 3/17] RUN pipx uninstal 0.0s
=> CACHED [dev_container_auto_added_stage_label 4/17] RUN pipx uninstal 0.0s
=> CACHED [dev_container_auto_added_stage_label 5/17] RUN pipx uninstal 0.0s
=> CACHED [dev_container_auto_added_stage_label 6/17] RUN pipx uninstal 0.0s
=> CACHED [dev_container_auto_added_stage_label 7/17] RUN pipx uninstal 0.0s
=> CACHED [dev_container_auto_added_stage_label 8/17] RUN curl -sS 0.0s
=> CACHED [dev_container_auto_added_stage_label 9/17] WORKDIR /usr/src 0.0s
=> CACHED [dev_container_auto_added_stage_label 10/17] RUN git clone --d 0.0s
=> CACHED [dev_container_auto_added_stage_label 11/17] WORKDIR /workspac 0.0s
=> CACHED [dev_container_auto_added_stage_label 12/17] COPY requirements 0.0s
=> CACHED [dev_container_auto_added_stage_label 13/17] COPY homeassistan 0.0s
=> ERROR [dev_container_auto_added_stage_label 14/17] RUN pip3 install - 0.0s
> [dev_container_auto_added_stage_label 14/17] RUN pip3 install -r requirements.txt --use-deprecated=legacy-resolver:
Dockerfile-with-features:50
48 | COPY requirements.txt ./
49 | COPY homeassistant/package_constraints.txt homeassistant/package_constraints.txt
50 | >>> RUN pip3 install -r requirements.txt --use-deprecated=legacy-resolver
51 | COPY requirements_test.txt requirements_test_pre_commit.txt ./
52 | RUN pip3 install -r requirements_test.txt --use-deprecated=legacy-resolver
[2445 ms] Error: Command failed: docker buildx build --load --build-arg BUILDKIT_INLINE_CACHE=1 -f /tmp/devcontainercli-root/container-features/0.23.2-1675421351075/Dockerfile-with-features -t vsc-core-a3326b3531d3eb2709cdfe792550e3f2 --target dev_containers_target_stage --build-arg _DEV_CONTAINERS_BASE_IMAGE=dev_container_auto_added_stage_label /workspaces/core
[2445 ms] at doe (/root/.vscode-remote-containers/dist/dev-containers-cli-0.262.3/dist/spec-node/devContainersSpecCLI.js:1888:1635)
[2445 ms] at processTicksAndRejections (node:internal/process/task_queues:96:5)
[2446 ms] at async pF (/root/.vscode-remote-containers/dist/dev-containers-cli-0.262.3/dist/spec-node/devContainersSpecCLI.js:1887:1973)
[2446 ms] at async eT (/root/.vscode-remote-containers/dist/dev-containers-cli-0.262.3/dist/spec-node/devContainersSpecCLI.js:1887:901)
[2446 ms] at async voe (/root/.vscode-remote-containers/dist/dev-containers-cli-0.262.3/dist/spec-node/devContainersSpecCLI.js:1893:2049)
[2446 ms] at async Xf (/root/.vscode-remote-containers/dist/dev-containers-cli-0.262.3/dist/spec-node/devContainersSpecCLI.js:1893:3212)
[2446 ms] at async Jae (/root/.vscode-remote-containers/dist/dev-containers-cli-0.262.3/dist/spec-node/devContainersSpecCLI.js:2013:15058)
[2446 ms] at async Wae (/root/.vscode-remote-containers/dist/dev-containers-cli-0.262.3/dist/spec-node/devContainersSpecCLI.js:2013:14812)
[2452 ms] Exit code 1
[2452 ms] Start: Run: docker rm -f 1e19ca7fda518186dd0c291082d0c296ac901a14b5d61b64c578902174f0b067
[2460 ms] Command failed: node /root/.vscode-remote-containers/dist/dev-containers-cli-0.262.3/dist/spec-node/devContainersSpecCLI.js up --workspace-folder /workspaces/core --workspace-mount-consistency cached --id-label vsch.local.repository=https://github.com/jfparis/core --id-label vsch.local.repository.volume=core-baa6bbc339a19ee8eb6de6eb83e60123 --id-label vsch.local.repository.folder=core --log-level debug --log-format json --config /workspaces/core/.devcontainer/devcontainer.json --override-config /tmp/devcontainer-64089032-dba1-4800-877f-fa8b96386d89.json --default-user-env-probe loginInteractiveShell --mount type=volume,source=core-baa6bbc339a19ee8eb6de6eb83e60123,target=/workspaces,external=true --mount type=volume,source=vscode,target=/vscode,external=true --skip-post-create --update-remote-user-uid-default off --mount-workspace-git-root true
[2460 ms] Exit code 1
[2536 ms] Container server terminated (code: 137, signal: null).
