I am trying to install TP Link Omada integration. I am currently running Home Assistant Core 2024.11.3. On a Proxmox VM. I try connecting using different methos of url. I use 192.168.11.2 and http://192.168.11.2 and knowing it shouldn’t work https://192.168.11.2. I input my Omada admin username and password. I keep getting failed to connect. I have unselected Verify SSL certificate to see if that would work - no help. I have created seperate duplicate VM on the same Vlan as my Omada network and get same results. “Failed to connect” I have checked logs in my Omada controller and there are no failed login attempts. Has anyone been able to get this to work?
