HA running on Raspberry pi 4 with Conbee II.
When starting zigbee2mqtt I get this in the logs :
Zigbee2MQTT:error 2022-01-28 15:46:26: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:102:27)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:123:29)
at Zigbee.start (/app/lib/zigbee.ts:58:27)
at Controller.start (/app/lib/controller.ts:100:27)
at start (/app/index.js:97:5)
[15:46:27] INFO: Handing over control to Zigbee2mqtt Core …
Somewhere I read i had to add the following to zigbee2mqtt configuration file :
adapter : deconz
but no luck…
Conbee is correctly installed and recognized (works just fine with deconz) :
I don’t know what else to do…
