Hi Home Assistant users,
I could do with some assistants!
I am trying to configure my EnOcean USB 300 USB gateway in HA but I get this message from HA States page
Invalid Config
The following components and platforms could not be set up:
enocean
Please check your config
I have installed Home Assistant on Volumio 2 (Raspbian Jessie) on a Rpi3 according to instructions found on here i.e I have HA in virtual environment and I have added user homeassistant to dialout grupe.
My USB 300 USB gateway has the path /dev/ttyUSB0 and my entry in configuration.yaml looks like this:
# EnOcean
device: /dev/ttyUSB0```
(there are two blank spaces in front of "device:" but I can't get the forum formatting to show it correctly)
I have verified with a python 3 script that I can talk to /dev/ttyUSB0 (open, write, close from within HA virtual environment).
If I open HA log I get one error message at the end that looks like it could have something to do with my problem but I am not sure (see log below).
Is there anybody who has any idea what could be wrong?!
yoggi
```2017-06-03 12:05:16 ERROR (MainThread) [homeassistant.setup] Error during setup of c$
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/setup.py", line$
None, component.setup, hass, processed_config)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/enoc$
ENOCEAN_DONGLE = EnOceanDongle(hass, serial_dev)
from enocean.communicators.serialcommunicator import SerialCommunicator
File "/home/homeassistant/.homeassistant/deps/enocean/communicators/serialcommunic$
from enocean.communicators.communicator import Communicator
File "/home/homeassistant/.homeassistant/deps/enocean/communicators/communicator.p$
from enocean.protocol.packet import Packet
File "/home/homeassistant/.homeassistant/deps/enocean/protocol/packet.py", line 10$
eep = EEP()
File "/home/homeassistant/.homeassistant/deps/enocean/protocol/eep.py", line 17, i$
self.soup = BeautifulSoup(f.read(), "html.parser")
File "/usr/lib/python3.4/encodings/ascii.py", line 26, in decode
return codecs.ascii_decode(input, self.errors)[0]
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc2 in position 2119: ordinal n$```
