After attempting to update to 74.0 I was unable to visit my home-assistant server.
It was providing “404: Not Found” for all normal endpoints.
Only error that I can see is the following:
ERROR (MainThread) [homeassistant.setup] Error during setup of component frontend Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/homeassistant/setup.py", line 143, in _async_setup_component hass, processed_config) File "/usr/local/lib/python3.6/site-packages/homeassistant/components/frontend/__init__.py", line 228, in async_setup hass_frontend_path = hass_frontend.where() AttributeError: module 'hass_frontend' has no attribute 'where' 2018-07-28 15:03:06 ERROR (MainThread) [homeassistant.setup] Setup failed for nest: Component did not return boolean if setup was successful. Disabling component.
Using default config doesn’t seem to help.
Uninstall and reinstall using pip didn’t help.
I found that this could be due to the ‘aiohttp’ component so I’ve tried reinstalling it as well.
Right now I’m a bit stuck at what to try next. Does anyone have an idea as what to try next or what it might be?
