Fallback Devices similar to aliases
I would like to request a UI way to define Fallback devices in case a device/entity becomes “unavailable”. Then it goes through its internal list and “replaces itself” without actually replacing anything in the background with the first fallback device listed, that is available.
Basically this:
I case someone wants it; here’s a fallback light template for a light with a third simple switch fallback:
src: https://github.com/Bluscream/homeassistant-config/blob/main/light/ceiling_light.yaml
  lights:
    ceiling_light:
      unique_id: ceiling_light
      friendly_name: "Ceiling Light"
      icon_template: "mdi:ceiling-light"
      value_template: >
        {% if not is_state('light.ceiling_light_local', 'unavailable') %}{{states('light.ceiling_light_local')}}
        {% elif not is_state('light.ceiling_light_cloud', 'unavailable') %}{{states('light.ceiling_light_cloud')}}
        {% else %}{{states('switch.smart_ceiling_lamp_relay')}}
        {% endif %}
      turn_on:
        - service: switch.turn_on
            entity_id: switch.smart_ceiling_lamp_relay
        - service: light.turn_on
            entity_id: "{{ 'light.ceiling_light_local' if not is_state('light.ceiling_light_local', 'unavailable') else 'light.ceiling_light_cloud'}}"
      turn_off:
        - service: >
            {% if not is_state('light.ceiling_light_local', 'unavailable') %}light.turn_off
            {% elif not is_state('light.ceiling_light_cloud', 'unavailable') %}light.turn_off
            {% else %}switch.turn_off
            {% endif %}
            entity_id: >
              {% if not is_state('light.ceiling_light_local', 'unavailable') %}light.ceiling_light_local
              {% elif not is_state('light.ceiling_light_cloud', 'unavailable') %}light.ceiling_light_cloud
              {% else %}switch.smart_ceiling_lamp_relay
              {% endif %}
      set_level:
        data_template:
          entity_id: "{{ 'light.ceiling_light_local' if not is_state('light.ceiling_light_local', 'unavailable') else 'light.ceiling_light_cloud' }}"
          brightness: "{{ brightness }}"
      set_temperature:
        data_template:
          color_temp: "{{ color_temp }}"
      set_color:
        data_template:
          hs_color:
            - "{{ h }}"
            - "{{ s }}"
      supports_transition_template: false
Here’s one for a single fallback fan:
src: https://github.com/Bluscream/homeassistant-config/blob/main/fan/ventilator.yaml
  fans:
    ventilator:
      unique_id: ventilator
      friendly_name: "Ventilator"
      # icon_template: "mdi:fan"
      value_template: "{{ states('switch.fan_socket_local') if not is_state('switch.fan_socket_local', 'unavailable') else states('switch.fan_socket_cloud') }}"
      percentage_template: 100
      turn_on:
            entity_id: "{{ 'switch.fan_socket_local' if not is_state('switch.fan_socket_local', 'unavailable') else 'switch.fan_socket_cloud'}}"
      turn_off:
        - service: switch.turn_off
            entity_id: "{{ 'switch.fan_socket_local' if not is_state('switch.fan_socket_local', 'unavailable') else 'switch.fan_socket_cloud' }}"
