Hi all. Since updating to the latest build, when I click on Restart in Server Controls, nothing happens. There is no way to restart HA from the web interface. Is anybody else encountering the same issue?
<False alarm> - SOLVED - Restart not working since updating to latest build - Home Assistant 0.104.2
Have you checked the log file? HA will not restart if there are errors in your configuration
Thank you David, bad config on my part. It was my first monumental screwup that stopped the service from functioning. I backed the change out using Samba and all is well. Thank you again!
