Solved my own after trying a few things. So here is the process in case someone wants to show/hide calendars from an external button (similar to what the legend does).
Create an input text helper with default value .* (input_text.holiday_calendar_filter)
Created a script that will toggle the values of .* and $^ to filter none or filter all events in the calendar:
Was This ever added? I really want to always show a full month view no matter what day it is today, maybe with today highlighted.
However I cant find any way to do this, Is there a way to start the month on the 1st and display the whole month regardless if the 1st day has passed and it is the 6th or whatever?
//Edit Found it in the closed issues on GitHub, it was added but its not obvious how you do this.
To do a full month starting on 1 and ending on last day of month you need to type in “month” for the total days under “days” .
Now the tricky part is you also need to type in “month” for starting day which is a drop down and doesn’t include this or allow you to type it.
You will need to edit this to “month” in the code editor as below :
days: month
I would ask there is a more obvious setting added to the gui for this view in future.
Thank you for posting this! I was literally searching for the same thing. My issue is that I always want the page to look like a calendar with Sunday being the first day of the week. I feel like the solution you posted above will not allow that since “month” makes the first day of the week be today.
Ugh.
All i want is a calendar card to show the entire month with sunday being the first day. Imagine you were looking at a printed calendar on a wall. That’s what I am hoping for someday with this card. It is AMAZING otherwise!
Finally got my pi and imaged with HA.
I’ve got it on the local network and have been playing about with some very basic dashboard concepts along with integration with Google Calendar.
However I now want to look at these custom dashboards for the family planners.
There are a lot of examples in this thread which show solutions at a code level.
Where do you save this code. I’m assuming its not as easy as doing it from the gui. I’m expecting some level of cli involvement. But a few articles I read reference different cli directories for saving these scripts.
Any pointers for a newbie or even reference to good newbie guides would be appreciated.
Hi, the card code has to be added to your dashboard.
Additionally, there is YAML code in this thread for automations (or scripts) which can also be used/added in the webUI
Which article?
The first post, which is about this calendar, refers to GH where all is explained.
If I scroll a few posts up, there are some cards as well and those are installed the way I mentioned in my previous post and the other YAML code is for automations.
None of that needs access to your file system but if you want do that: the keywords are Samba or SSH access to your system.
I’m running the main OS, on a raspberry pi 5. So no docker container or stripped down version. Hopefully that makes sense.
If I use the cli directly my display shows the ASCII art HA banner with a green ha> prompt
If I type “login” it takes me into the main shell
But when I try to type in “cd /config” it cant find the directory ← This is suggested on most posts I found
I can find a “config” folder in other directories but there are 2 or 3 of them, so its knowing which is the right one I think.
But then none of them have a “/www” sub folder so I’m guessing I would then have to do a “mkdir www” or something
In the Add-ons (sidebar → settings) you can search for SSH or Samba.
With Samba you can just use your file manager from your OS or with SSH and for instance WinSCP (on windows) to transfer those files.
Thanks for confirming this. I assume I could have used nano or viz in linux as well. That said a drag and drop function is easier anyway
The next challenge I have is, that it suggest placing the file into “/config/www” but I dont have this anywhere.
There seem to be many posts confirming different locations for it. But I think because this is the raw HA OS on a pi (no container) that most posts reference
“/mnt/data/supervisor/homeassistant/config”
But I dont have the config directory and therefore obviously not the /www either
Do I just create this final folder structure, or is it actually a different path?
If you go to Sidebar → System → Repairs → 3 dots top right hand → System information, you can see where your configuration is stored.
That is the config dir mentioned above.
For the js file, you could use wget I guess as well and you can use the UI in Settings → Dashboards → Resources to add a reference to the js file.
For anyone who needs this, I thought I’d share: I needed to color events based on their contents/title as opposed to which calendar they originate from. Use case: a calendar that shows pick-up dates for waste and waste recycling containers. Each of these containers has a distinct color, and I wanted to link that color to the relevant pickup day.
So if you have a calendar with recurring events, that always have the same title, and you want to color these based on their title; here’s how to do that with card_mod:
(just change the contents of the data-summary selector to fit your event titles)
