So I have a Fan that I automate via Wifi (Wemos D1 Mini with ESPHome). It’s all working perfectly expect for the deprecated fan_speed
setting, but that’ another story.
So I want to trigger the Fan at midnight (00:00) and in the morning (08:00). At midnight, speed should go back to 1 (0% - ‘off’) and in the morning speed should go to 2 (33%). These times also turn the Automatic Fan Mode input boolean to on. I also have an input boolean that triggers once I make adjustments to the state_attribute: percentage
i.e. I make manual adjustments. The input boolean Automatic Fan Mode will then turn off.
So now comes the tricky part, but maybe easy for you guys: because at midnight and in the morning the automations for the fan percentage are triggered, the input boolean will turn off. I now workaround that in my automation to wait 1 second and then turn the input boolean back on. But I don’t like this, and since I like dabbling in YAML, there should be a cleaner way right?
Is there a way to incorporate the automation to ONLY trigger by adjusting myself and not to trigger when an automation changes the fan percentage?
This is my YAML for my input boolean automation:
# Automation to automatically start fan at certain times.
# Resets itself at midnight if input_boolean is overriden.
# Sets midnight and morning speed.
alias: "Fan Automatic Mode off"
mode: single
platform: state
entity_id: fan.zehnder_e300
condition:
condition: and
conditions:
- condition: state
entity_id: input_boolean.automatic_fan_mode
state: "on"
- condition: or
conditions:
- condition: state
state: "off"
- condition: template
value_template: >
{{ trigger.from_state and trigger.to_state.attributes.percentage != trigger.from_state.attributes.percentage }}
- alias: "Turn Automatic Fan Mode off"
service: input_boolean.turn_off
And here is the automation for the fan percentages at midnight and in the morning:
# Automation to set the fan to speed 1 at night or speed 2 in the morning
# depends on input_boolean
alias: "Fan speed 1 (midnight) and Fan speed 2 (morning)"
mode: restart
platform: time
at:
- input_datetime.midnight # Triggers at 00:00
- input_datetime.morning # Triggers at 08:00
condition:
alias: "Input Boolean Automatic Fan Mode on"
condition: state
state: "on"
choose:
- conditions:
- alias: "Wait till midnight"
condition: time
after: input_datetime.midnight
before: input_datetime.morning
sequence:
- alias: "Set fan speed to 1"
service: fan.set_percentage
percentage: 0
- delay: 1
- alias: "Turn Input Boolean back on"
service: input_boolean.turn_on
- conditions:
- alias: "Wait till morning"
condition: time
after: input_datetime.morning
before: input_datetime.midnight
sequence:
- alias: "Set fan speed to 2"
percentage: 33
- delay: 1
