Fan Control with automatic and manual mode
Good Morning,
i need help with these Code. The automatic temperature control should only work if the automatic switch is turned on. Is the code correct?
esphome:
	name: "Steuerung Luftaustausch"
    friendly_name: steuerung_luftaustausch
	platform: ESP8266
    board: nodemcuv2
    #logging, wifi etc.
# IRF520 Mosfet
output:
  - platform: esp8266_pwm
    pin: D5
    frequency: 16000 Hz
# Fan
fan:
  - platform: speed
    output: fridge_fans
# Temperature Sensor
  - platform: dht
    pin: GPIO2
    update_interval: 5s
    temperature:
      on_value_range:
          then:
          	- if:
            	condition:
                	and:
						- switch.is_on: automatic
                    	- below: 25.0
          		then:
            		- fan.turn_off: fan
          	- if:
            	condition:
                	and:
                    	- above: 25.1
                          below: 27.0
          		then:
            		- switch.turn_on: fan_low
          	- if:
            	condition:
                	and:
                    	- above: 27.1
                          below: 29.0
          		then:
            		- switch.turn_on: fan_med
          	- if:
            	condition:
                	and:
                    	- above: 29
          		then:
            		- switch.turn_on: fan_hig
    humidity:
# Fan Speed
switch:
    name: ${friendly_name} Automatik
    turn_on_action:
      - fan.turn_on:
          speed: LOW
    turn_on_action:
      - fan.turn_on:
          speed: MEDIUM
    turn_on_action:
      - fan.turn_on:
          speed: HIGH
Only you can tell that…
What output is that? Not something in your yaml anyway…
Maybe you should try with pwm_fan
