I was able to delete the device from the integration and before I add it back, here is what it looks like from the Tasmota interface:
Toggle 1 is the fan and Toggle 2 is the light. I always wondered that the fan is just a toggle???
Here is the information on the device:
And is the template:
Here is a copy of the console when I issue TuyaMCU 12,102
00:00:00.001 HDW: ESP8266EX
00:00:00.050 CFG: Loaded from flash at F5, Count 223
00:00:00.055 QPC: Count 1
00:00:00.107 SNS: Hardware Serial
00:00:00.144 Project tasmota Main Lucci Version 9.5.0(tasmota)-2_7_4_9(2021-06-17T08:26:35)
00:00:00.531 WIF: Connecting to AP1 IoT_2GHz Channel 6 BSSId F2:63:DA:A1:73:65 in mode 11n as Main_Lucci...
00:00:02.754 WIF: Connected
13:22:41.080 RUL: TUYARECEIVED#DATA=55AA00070005020400010113 performs "publish2 stat/Main_Ceiling_Fan/speed 2,1"
13:22:41.084 RSL: speed = 2,1
13:22:42.035 HTP: Web server active on Main_Lucci with IP address 192.168.72.105
13:22:43.015 MQT: Attempting connection...
13:22:43.028 MQT: Connected
13:22:43.031 MQT: tele/Main_Lucci/LWT = Online (retained)
13:22:43.033 MQT: cmnd/Main_Lucci/POWER =
13:22:43.046 MQT: tele/Main_Lucci/INFO1 = {"Info1":{"Module":"Lucci Fan","Version":"9.5.0(tasmota)","FallbackTopic":"cmnd/DVES_66AFB2_fb/","GroupTopic":"cmnd/tasmotas/"}}
13:22:43.061 MQT: tele/Main_Lucci/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"Main_Lucci","IPAddress":"192.168.72.105"}}
13:22:43.075 MQT: tele/Main_Lucci/INFO3 = {"Info3":{"RestartReason":"Software/System restart"}}
13:22:43.088 MQT: stat/Main_Lucci/RESULT = {"POWER1":"OFF"}
13:22:43.089 MQT: stat/Main_Lucci/POWER1 = OFF
13:22:43.091 MQT: stat/Main_Lucci/RESULT = {"POWER2":"OFF"}
13:22:43.093 MQT: stat/Main_Lucci/POWER2 = OFF
13:22:43.288 MQT: tele/Main_Lucci/STATE = {"Time":"2021-07-03T13:22:43","Uptime":"0T00:00:06","UptimeSec":6,"Heap":28,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"IoT_2GHz","BSSId":"F2:63:DA:A1:73:65","Channel":5,"Mode":"11n","RSSI":56,"Signal":-72,"LinkCount":1,"Downtime":"0T00:00:03"}}
13:22:45.782 MQT: stat/Main_Lucci/STATUS = {"Status":{"Module":0,"DeviceName":"Main Lucci","FriendlyName":["Main Fan","Main Light"],"Topic":"Main_Lucci","ButtonTopic":"0","Power":0,"PowerOnState":0,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0}}
13:22:45.801 MQT: stat/Main_Lucci/STATUS1 = {"StatusPRM":{"Baudrate":9600,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://192.168.72.15:9541/data/firmwares/tasmota.bin","RestartReason":"Software/System restart","Uptime":"0T00:00:08","StartupUTC":"2021-07-03T03:22:37","Sleep":50,"CfgHolder":4617,"BootCount":47,"BCResetTime":"2021-04-07T12:39:30","SaveCount":224,"SaveAddress":"F4000"}}
13:22:45.817 MQT: stat/Main_Lucci/STATUS2 = {"StatusFWR":{"Version":"9.5.0(tasmota)","BuildDateTime":"2021-06-17T08:26:35","Boot":31,"Core":"2_7_4_9","SDK":"2.2.2-dev(38a443e)","CpuFrequency":80,"Hardware":"ESP8266EX","CR":"349/699"}}
13:22:45.834 MQT: stat/Main_Lucci/STATUS3 = {"StatusLOG":{"SerialLog":0,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["IoT_2GHz",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["000A8009","2805C8000100060000005A0A000000000000","00000280","00006000","00000000"]}}
13:22:45.854 MQT: stat/Main_Lucci/STATUS4 = {"StatusMEM":{"ProgramSize":607,"Free":396,"Heap":27,"ProgramFlashSize":1024,"FlashSize":2048,"FlashChipId":"1540C8","FlashFrequency":40,"FlashMode":3,"Features":["00000809","8FDAC787","04368001","000000CF","010013C0","C000F981","00004004","00001000","00000020"],"Drivers":"1,2,3,4,5,6,7,8,9,10,12,16,18,19,20,21,22,24,26,27,29,30,35,37,45","Sensors":"1,2,3,4,5,6"}}
13:22:45.875 MQT: stat/Main_Lucci/STATUS5 = {"StatusNET":{"Hostname":"Main_Lucci","IPAddress":"192.168.72.105","Gateway":"192.168.72.1","Subnetmask":"255.255.255.0","DNSServer":"192.168.72.1","Mac":"B4:E6:2D:66:AF:B2","Webserver":2,"WifiConfig":4,"WifiPower":17.0}}
13:22:45.892 MQT: stat/Main_Lucci/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.72.15","MqttPort":1883,"MqttClientMask":"DVES_%06X","MqttClient":"DVES_66AFB2","MqttUser":"mozzie","MqttCount":1,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4}}
13:22:45.912 MQT: stat/Main_Lucci/STATUS7 = {"StatusTIM":{"UTC":"2021-07-03T03:22:45","Local":"2021-07-03T13:22:45","StartDST":"2021-03-28T02:00:00","EndDST":"2021-10-31T03:00:00","Timezone":"+10:00","Sunrise":"13:52","Sunset":"05:56"}}
13:22:45.930 MQT: stat/Main_Lucci/STATUS10 = {"StatusSNS":{"Time":"2021-07-03T13:22:45"}}
13:22:45.950 MQT: stat/Main_Lucci/STATUS11 = {"StatusSTS":{"Time":"2021-07-03T13:22:45","Uptime":"0T00:00:08","UptimeSec":8,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"IoT_2GHz","BSSId":"F2:63:DA:A1:73:65","Channel":5,"Mode":"11n","RSSI":56,"Signal":-72,"LinkCount":1,"Downtime":"0T00:00:03"}}}
13:22:45.029 QPC: Reset
13:22:47.812 MQT: tele/Main_Lucci/STATE = {"Time":"2021-07-03T13:22:47","Uptime":"0T00:00:10","UptimeSec":10,"Heap":28,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"IoT_2GHz","BSSId":"F2:63:DA:A1:73:65","Channel":5,"Mode":"11n","RSSI":54,"Signal":-73,"LinkCount":1,"Downtime":"0T00:00:03"}}
13:22:52.950 MQT: homeassistant/switch/66AFB2_RL_2/config = {"name":"Main Light","stat_t":"tele/Main_Lucci/STATE","avty_t":"tele/Main_Lucci/LWT","pl_avail":"Online","pl_not_avail":"Offline","cmd_t":"cmnd/Main_Lucci/POWER2","pl_off":"OFF","pl_on":"ON","val_tpl":"{{value_json.POWER2}}","uniq_id":"66AFB2_RL_2","dev":{"ids":["66AFB2"]}} (retained)
13:22:52.962 MQT: homeassistant/sensor/66AFB2_status/config = {"name":"Main Lucci status","stat_t":"tele/Main_Lucci/HASS_STATE","avty_t":"tele/Main_Lucci/LWT","pl_avail":"Online","pl_not_avail":"Offline","json_attr_t":"tele/Main_Lucci/HASS_STATE","unit_of_meas":"%","val_tpl":"{{value_json['RSSI']}}","ic":"mdi:information-outline","uniq_id":"66AFB2_status","dev":{"ids":["66AFB2"],"name":"Main Lucci","mdl":"Lucci Fan","sw":"9.5.0(tasmota)","mf":"Tasmota"}} (retained)
13:22:53.982 MQT: stat/Main_Lucci/STATUS = {"Status":{"Module":0,"DeviceName":"Main Lucci","FriendlyName":["Main Fan","Main Light"],"Topic":"Main_Lucci","ButtonTopic":"0","Power":0,"PowerOnState":0,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0}}
13:22:54.002 MQT: stat/Main_Lucci/STATUS1 = {"StatusPRM":{"Baudrate":9600,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://192.168.72.15:9541/data/firmwares/tasmota.bin","RestartReason":"Software/System restart","Uptime":"0T00:00:16","StartupUTC":"2021-07-03T03:22:37","Sleep":50,"CfgHolder":4617,"BootCount":48,"BCResetTime":"2021-04-07T12:39:30","SaveCount":225,"SaveAddress":"FB000"}}
13:22:54.019 MQT: stat/Main_Lucci/STATUS2 = {"StatusFWR":{"Version":"9.5.0(tasmota)","BuildDateTime":"2021-06-17T08:26:35","Boot":31,"Core":"2_7_4_9","SDK":"2.2.2-dev(38a443e)","CpuFrequency":80,"Hardware":"ESP8266EX","CR":"349/699"}}
13:22:54.036 MQT: stat/Main_Lucci/STATUS3 = {"StatusLOG":{"SerialLog":0,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["IoT_2GHz",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["000A8009","2805C8000100060000005A0A000000000000","00000280","00006000","00000000"]}}
13:22:54.060 MQT: stat/Main_Lucci/STATUS4 = {"StatusMEM":{"ProgramSize":607,"Free":396,"Heap":27,"ProgramFlashSize":1024,"FlashSize":2048,"FlashChipId":"1540C8","FlashFrequency":40,"FlashMode":3,"Features":["00000809","8FDAC787","04368001","000000CF","010013C0","C000F981","00004004","00001000","00000020"],"Drivers":"1,2,3,4,5,6,7,8,9,10,12,16,18,19,20,21,22,24,26,27,29,30,35,37,45","Sensors":"1,2,3,4,5,6"}}
13:22:54.080 MQT: stat/Main_Lucci/STATUS5 = {"StatusNET":{"Hostname":"Main_Lucci","IPAddress":"192.168.72.105","Gateway":"192.168.72.1","Subnetmask":"255.255.255.0","DNSServer":"192.168.72.1","Mac":"B4:E6:2D:66:AF:B2","Webserver":2,"WifiConfig":4,"WifiPower":17.0}}
13:22:54.097 MQT: stat/Main_Lucci/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.72.15","MqttPort":1883,"MqttClientMask":"DVES_%06X","MqttClient":"DVES_66AFB2","MqttUser":"mozzie","MqttCount":1,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4}}
13:22:54.115 MQT: stat/Main_Lucci/STATUS7 = {"StatusTIM":{"UTC":"2021-07-03T03:22:54","Local":"2021-07-03T13:22:54","StartDST":"2021-03-28T02:00:00","EndDST":"2021-10-31T03:00:00","Timezone":"+10:00","Sunrise":"13:52","Sunset":"05:56"}}
13:22:54.134 MQT: stat/Main_Lucci/STATUS10 = {"StatusSNS":{"Time":"2021-07-03T13:22:54"}}
13:22:54.152 MQT: stat/Main_Lucci/STATUS11 = {"StatusSTS":{"Time":"2021-07-03T13:22:54","Uptime":"0T00:00:17","UptimeSec":17,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"IoT_2GHz","BSSId":"F2:63:DA:A1:73:65","Channel":5,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":1,"Downtime":"0T00:00:03"}}}
13:23:01.739 MQT: stat/Main_Lucci/STATUS = {"Status":{"Module":0,"DeviceName":"Main Lucci","FriendlyName":["Main Fan","Main Light"],"Topic":"Main_Lucci","ButtonTopic":"0","Power":0,"PowerOnState":0,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0}}
13:23:01.759 MQT: stat/Main_Lucci/STATUS1 = {"StatusPRM":{"Baudrate":9600,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://192.168.72.15:9541/data/firmwares/tasmota.bin","RestartReason":"Software/System restart","Uptime":"0T00:00:24","StartupUTC":"2021-07-03T03:22:37","Sleep":50,"CfgHolder":4617,"BootCount":48,"BCResetTime":"2021-04-07T12:39:30","SaveCount":225,"SaveAddress":"FB000"}}
13:23:01.776 MQT: stat/Main_Lucci/STATUS2 = {"StatusFWR":{"Version":"9.5.0(tasmota)","BuildDateTime":"2021-06-17T08:26:35","Boot":31,"Core":"2_7_4_9","SDK":"2.2.2-dev(38a443e)","CpuFrequency":80,"Hardware":"ESP8266EX","CR":"349/699"}}
13:23:01.794 MQT: stat/Main_Lucci/STATUS3 = {"StatusLOG":{"SerialLog":0,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["IoT_2GHz",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["000A8009","2805C8000100060000005A0A000000000000","00000280","00006000","00000000"]}}
13:23:01.817 MQT: stat/Main_Lucci/STATUS4 = {"StatusMEM":{"ProgramSize":607,"Free":396,"Heap":27,"ProgramFlashSize":1024,"FlashSize":2048,"FlashChipId":"1540C8","FlashFrequency":40,"FlashMode":3,"Features":["00000809","8FDAC787","04368001","000000CF","010013C0","C000F981","00004004","00001000","00000020"],"Drivers":"1,2,3,4,5,6,7,8,9,10,12,16,18,19,20,21,22,24,26,27,29,30,35,37,45","Sensors":"1,2,3,4,5,6"}}
13:23:01.839 MQT: stat/Main_Lucci/STATUS5 = {"StatusNET":{"Hostname":"Main_Lucci","IPAddress":"192.168.72.105","Gateway":"192.168.72.1","Subnetmask":"255.255.255.0","DNSServer":"192.168.72.1","Mac":"B4:E6:2D:66:AF:B2","Webserver":2,"WifiConfig":4,"WifiPower":17.0}}
13:23:01.854 MQT: stat/Main_Lucci/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.72.15","MqttPort":1883,"MqttClientMask":"DVES_%06X","MqttClient":"DVES_66AFB2","MqttUser":"mozzie","MqttCount":1,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4}}
13:23:01.872 MQT: stat/Main_Lucci/STATUS7 = {"StatusTIM":{"UTC":"2021-07-03T03:23:01","Local":"2021-07-03T13:23:01","StartDST":"2021-03-28T02:00:00","EndDST":"2021-10-31T03:00:00","Timezone":"+10:00","Sunrise":"13:52","Sunset":"05:56"}}
13:23:01.887 MQT: stat/Main_Lucci/STATUS10 = {"StatusSNS":{"Time":"2021-07-03T13:23:01"}}
13:23:01.907 MQT: stat/Main_Lucci/STATUS11 = {"StatusSTS":{"Time":"2021-07-03T13:23:01","Uptime":"0T00:00:24","UptimeSec":24,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"IoT_2GHz","BSSId":"F2:63:DA:A1:73:65","Channel":5,"Mode":"11n","RSSI":56,"Signal":-72,"LinkCount":1,"Downtime":"0T00:00:03"}}}
13:23:09.757 MQT: stat/Main_Lucci/STATUS = {"Status":{"Module":0,"DeviceName":"Main Lucci","FriendlyName":["Main Fan","Main Light"],"Topic":"Main_Lucci","ButtonTopic":"0","Power":0,"PowerOnState":0,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0}}
13:23:09.777 MQT: stat/Main_Lucci/STATUS1 = {"StatusPRM":{"Baudrate":9600,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://192.168.72.15:9541/data/firmwares/tasmota.bin","RestartReason":"Software/System restart","Uptime":"0T00:00:32","StartupUTC":"2021-07-03T03:22:37","Sleep":50,"CfgHolder":4617,"BootCount":48,"BCResetTime":"2021-04-07T12:39:30","SaveCount":225,"SaveAddress":"FB000"}}
13:23:09.794 MQT: stat/Main_Lucci/STATUS2 = {"StatusFWR":{"Version":"9.5.0(tasmota)","BuildDateTime":"2021-06-17T08:26:35","Boot":31,"Core":"2_7_4_9","SDK":"2.2.2-dev(38a443e)","CpuFrequency":80,"Hardware":"ESP8266EX","CR":"349/699"}}
13:23:09.812 MQT: stat/Main_Lucci/STATUS3 = {"StatusLOG":{"SerialLog":0,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["IoT_2GHz",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["000A8009","2805C8000100060000005A0A000000000000","00000280","00006000","00000000"]}}
13:23:09.837 MQT: stat/Main_Lucci/STATUS4 = {"StatusMEM":{"ProgramSize":607,"Free":396,"Heap":27,"ProgramFlashSize":1024,"FlashSize":2048,"FlashChipId":"1540C8","FlashFrequency":40,"FlashMode":3,"Features":["00000809","8FDAC787","04368001","000000CF","010013C0","C000F981","00004004","00001000","00000020"],"Drivers":"1,2,3,4,5,6,7,8,9,10,12,16,18,19,20,21,22,24,26,27,29,30,35,37,45","Sensors":"1,2,3,4,5,6"}}
13:23:09.857 MQT: stat/Main_Lucci/STATUS5 = {"StatusNET":{"Hostname":"Main_Lucci","IPAddress":"192.168.72.105","Gateway":"192.168.72.1","Subnetmask":"255.255.255.0","DNSServer":"192.168.72.1","Mac":"B4:E6:2D:66:AF:B2","Webserver":2,"WifiConfig":4,"WifiPower":17.0}}
13:23:09.872 MQT: stat/Main_Lucci/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.72.15","MqttPort":1883,"MqttClientMask":"DVES_%06X","MqttClient":"DVES_66AFB2","MqttUser":"mozzie","MqttCount":1,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4}}
13:23:09.890 MQT: stat/Main_Lucci/STATUS7 = {"StatusTIM":{"UTC":"2021-07-03T03:23:09","Local":"2021-07-03T13:23:09","StartDST":"2021-03-28T02:00:00","EndDST":"2021-10-31T03:00:00","Timezone":"+10:00","Sunrise":"13:52","Sunset":"05:56"}}
13:23:09.908 MQT: stat/Main_Lucci/STATUS10 = {"StatusSNS":{"Time":"2021-07-03T13:23:09"}}
13:23:09.926 MQT: stat/Main_Lucci/STATUS11 = {"StatusSTS":{"Time":"2021-07-03T13:23:09","Uptime":"0T00:00:32","UptimeSec":32,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":25,"MqttCount":1,"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"IoT_2GHz","BSSId":"F2:63:DA:A1:73:65","Channel":5,"Mode":"11n","RSSI":56,"Signal":-72,"LinkCount":1,"Downtime":"0T00:00:03"}}}
13:23:17.937 MQT: stat/Main_Lucci/STATUS = {"Status":{"Module":0,"DeviceName":"Main Lucci","FriendlyName":["Main Fan","Main Light"],"Topic":"Main_Lucci","ButtonTopic":"0","Power":0,"PowerOnState":0,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0}}
13:23:17.957 MQT: stat/Main_Lucci/STATUS1 = {"StatusPRM":{"Baudrate":9600,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://192.168.72.15:9541/data/firmwares/tasmota.bin","RestartReason":"Software/System restart","Uptime":"0T00:00:40","StartupUTC":"2021-07-03T03:22:37","Sleep":50,"CfgHolder":4617,"BootCount":48,"BCResetTime":"2021-04-07T12:39:30","SaveCount":225,"SaveAddress":"FB000"}}
13:23:17.974 MQT: stat/Main_Lucci/STATUS2 = {"StatusFWR":{"Version":"9.5.0(tasmota)","BuildDateTime":"2021-06-17T08:26:35","Boot":31,"Core":"2_7_4_9","SDK":"2.2.2-dev(38a443e)","CpuFrequency":80,"Hardware":"ESP8266EX","CR":"349/699"}}
13:23:17.991 MQT: stat/Main_Lucci/STATUS3 = {"StatusLOG":{"SerialLog":0,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["IoT_2GHz",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["000A8009","2805C8000100060000005A0A000000000000","00000280","00006000","00000000"]}}
13:23:18.001 MQT: stat/Main_Lucci/STATUS4 = {"StatusMEM":{"ProgramSize":607,"Free":396,"Heap":27,"ProgramFlashSize":1024,"FlashSize":2048,"FlashChipId":"1540C8","FlashFrequency":40,"FlashMode":3,"Features":["00000809","8FDAC787","04368001","000000CF","010013C0","C000F981","00004004","00001000","00000020"],"Drivers":"1,2,3,4,5,6,7,8,9,10,12,16,18,19,20,21,22,24,26,27,29,30,35,37,45","Sensors":"1,2,3,4,5,6"}}
13:23:18.021 MQT: stat/Main_Lucci/STATUS5 = {"StatusNET":{"Hostname":"Main_Lucci","IPAddress":"192.168.72.105","Gateway":"192.168.72.1","Subnetmask":"255.255.255.0","DNSServer":"192.168.72.1","Mac":"B4:E6:2D:66:AF:B2","Webserver":2,"WifiConfig":4,"WifiPower":17.0}}
13:23:18.038 MQT: stat/Main_Lucci/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.72.15","MqttPort":1883,"MqttClientMask":"DVES_%06X","MqttClient":"DVES_66AFB2","MqttUser":"mozzie","MqttCount":1,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4}}
13:23:18.056 MQT: stat/Main_Lucci/STATUS7 = {"StatusTIM":{"UTC":"2021-07-03T03:23:18","Local":"2021-07-03T13:23:18","StartDST":"2021-03-28T02:00:00","EndDST":"2021-10-31T03:00:00","Timezone":"+10:00","Sunrise":"13:52","Sunset":"05:56"}}
13:23:18.073 MQT: stat/Main_Lucci/STATUS10 = {"StatusSNS":{"Time":"2021-07-03T13:23:18"}}
13:23:18.094 MQT: stat/Main_Lucci/STATUS11 = {"StatusSTS":{"Time":"2021-07-03T13:23:18","Uptime":"0T00:00:41","UptimeSec":41,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"IoT_2GHz","BSSId":"F2:63:DA:A1:73:65","Channel":5,"Mode":"11n","RSSI":50,"Signal":-75,"LinkCount":1,"Downtime":"0T00:00:03"}}}
Help me Obi-Wan Kenobi your my only hope.
