I have a ventilation system that has a tcp modbus.
My configuration:
modbus:
type: tcp
host: 192.xx.xx.xx
port: 502
fan:
fans:
ventilation:
friendly_name: "Ventilation system"
value_template: "{{ states('fan.ventilation', 'on') }}"
speed_template: "{{ states('fan.ventilation.speeds') }}"
turn_on:
service: modbus.write_register
unit: 1
address: 1
value: 2
turn_off:
unit: 1
address: 1
value: 0
set_speed:
data_template:
unit: 1
address: 1
value: "{{ speed }}"
speeds:
- '1'
- '2'
- '3'
If I go to Developer Tools → Services and select:
Service: fan.turn_on
Entity: fan.ventilation
and hit CALL SERVICE it is starting the ventilation system so it’s working. (also working for fan.turn_off, fan.set_speed)
Using the fan template things do not work.
Any suggestions?
Also, when starting home assistant I see this on the logs:
2018-08-10 07:02:02 ERROR (MainThread) [homeassistant.helpers.entity] Update for fan.ventilation fails
File “/usr/src/app/homeassistant/helpers/entity.py”, line 199, in async_update_ha_state
yield from self.async_device_update()
File “/usr/src/app/homeassistant/helpers/entity.py”, line 320, in async_device_update
yield from self.async_update()
File “/usr/src/app/homeassistant/components/fan/template.py”, line 302, in async_update
state = self._template.async_render()
File “/usr/src/app/homeassistant/helpers/template.py”, line 132, in async_render
return self._compiled.render(kwargs).strip()
File “/usr/local/lib/python3.6/site-packages/jinja2/asyncsupport.py”, line 76, in render
return original_render(self, *args, **kwargs)
File “/usr/local/lib/python3.6/site-packages/jinja2/environment.py”, line 1008, in render
return self.environment.handle_exception(exc_info, True)
File “/usr/local/lib/python3.6/site-packages/jinja2/environment.py”, line 780, in handle_exception
reraise(exc_type, exc_value, tb)
File “/usr/local/lib/python3.6/site-packages/jinja2/_compat.py”, line 37, in reraise
raise value.with_traceback(tb)
File “”, line 1, in top-level template code
File “/usr/local/lib/python3.6/site-packages/jinja2/sandbox.py”, line 427, in call
return __context.call(__obj, *args, **kwargs)
TypeError: call() takes 2 positional arguments but 3 were given
Thanks.
