Hi, i’ve spent the last few weeks trying to automate my ceiling fan using a Broadlink RM Pro. I have a toggle setup on my dashboard to turn it on which was working, but then I tried to setup an input boolean to remember the state, and then it started giving me the following error when I try and switch it on/off.
failed to call service fan/turn_on. extra keys not allowed @ data['target']
Below is the config I have. I assume it doesnt like the input_boolean code in the scripts.yaml, but i’ve seen other people using this same code.
I’m surprised at how difficult this config has been. I thought setting up the RF scripts would be hard but that was a walk in the park compared to setting up these scripts. This is just to get the fan to turn on/off, i’m not even at the point of trying to get the speeds or direction working.
Any help appreciated.
configuration.yaml
fan:
fans:
living_room_fan:
friendly_name: "Living Room Fans"
value_template: "{{ states('input_boolean.living_room_fan_state') }}"
percentage_template: "{{ states('input_number.living_room_fan_percentage') }}"
direction_template: "{{ states('input_select.living_room_fan_direction') }}"
turn_on:
service: script.living_room_fans_power_on
turn_off:
service: script.living_room_fans_power_off
set_direction:
service: script.living_room_fans_direction
data_template:
direction: "{{ direction }}"
set_percentage:
service: script.fans_set_speed
data_template:
percentage: "{{ percentage }}"
speed_count: 6
scripts.yaml
living_room_fans_power_on:
alias: living_room_fans_power_on
sequence:
- service: remote.send_command
device: living_room_fans
command: power_on
entity_id: remote.rm_pro_remote
entity_id: input_boolean.living_room_fan_state
living_room_fans_power_off:
alias: living_room_fans_power_off
sequence:
command: power_off
- service: input_boolean.turn_off
