I’m totally newbie writing HA templates and I created the next script to use in a fan template entity. I tested the script and works fine changing the slider and executing it, but I don’t have idea how to pass the input_number like an argument to the script inside the fan template.
alias: Study fan speed action
sequence:
- choose:
- conditions:
- condition: state
entity_id: input_number.study_fan_speed_selector
state: '0.0'
sequence:
- choose:
- conditions:
- condition: state
entity_id: switch.speed_1
state: 'on'
sequence:
- service: switch.turn_off
- conditions:
- condition: state
entity_id: switch.speed_2
state: 'on'
sequence:
- conditions:
- condition: state
entity_id: switch.speed_3
state: 'on'
sequence:
- conditions:
- condition: state
entity_id: switch.speed_4
state: 'on'
sequence:
default: []
- service: input_boolean.turn_off
entity_id: input_boolean.study_fan_state
- conditions:
- condition: state
state: '25.0'
sequence:
- service: switch.turn_on
- conditions:
- condition: state
state: '50.0'
sequence:
- conditions:
- condition: state
state: '75.0'
sequence:
- conditions:
- condition: state
state: '100.0'
sequence:
default: []
mode: single
and this other script:
alias: Study fan speed set
sequence:
- service: input_number.set_value
value: '{{ percentage }}'
- service: script.study_fan_speed_action
mode: single
And I need to pass the input_number value to create an entity fan with this code, but in not working:
fans:
study_fan:
friendly_name: "Ventilador Estudio"
value_template: "{{ states('input_boolean.study_fan_state') }}"
percentage_template: "{{ states('input_number.study_fan_speed_selector') }}"
turn_on:
service: script.study_fan_speed_set
value: 25.0
turn_off:
value: 0.0
set_percentage:
value: "{{ percentage }}"
speed_count: 4
Logger: homeassistant.helpers.script.ventilador_estudio
Source: helpers/script.py:1334
First occurred: 3:40:10 PM (2 occurrences)
Last logged: 3:40:25 PM
Ventilador Estudio: Error executing script. Invalid data for call_service at pos 1: expected float for dictionary value @ data['value']
What I’m doing wrong? Thanks.
I’ tried another implementation based on this post: https://community.home-assistant.io/t/help-new-template-fan-integration-percentage/286823/12?u=jjmuriel , but the error is the same.
fan:
fans:
study_fan:
turn_on:
service: script.study_fan_on
turn_off:
service: script.study_fan_off
set_percentage:
service: script.study_fan_set_speed_percent
speed_count: 4
script:
study_fan_off:
alias: Study Fan Off
sequence:
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
- conditions:
- condition: state
state: 'on'
sequence:
- conditions:
- condition: state
state: 'on'
sequence:
- conditions:
- condition: state
state: 'on'
sequence:
study_fan_on:
alias: Study Fan On
sequence:
- service: script.study_fan_set_speed_percent
study_fan_set_speed_percent:
alias: Study Fan Set Percentage
sequence:
entity_id: input_number.study_fan_speed_percentage
- delay:
milliseconds: 500
- service: >
{% if states("input_number.study_fan_speed_percentage") | int == 25 %}
script.study_fan_low_speed
{% elif states("input_number.study_fan_speed_percentage") | int == 50 %}
script.study_fan_medium_speed
{% elif states("input_number.study_fan_speed_percentage") | int == 75 %}
script.study_fan_medium_high_speed
{% elif states("input_number.study_fan_speed_percentage") | int == 100 %}
script.study_fan_high_speed
{% else %}
{% endif %}
- service: >
{% else %}
{% endif %}
study_fan_low_speed:
alias: Study Fan Low
sequence:
study_fan_medium_speed:
alias: Study Fan Medium
sequence:
study_fan_medium_high_speed:
alias: Study Fan Medium High
sequence:
study_fan_high_speed:
alias: Study Fan High
sequence:
* Ventilador Estudio: Error executing script. Invalid data for call_service at pos 1: expected float for dictionary value @ data['value']
I checked my code and I had a wrong input_number entity name. This is the fully working code:
# Scripts
study_fan_speed_action:
sequence:
- choose:
- conditions:
- condition: state
state: '0.0'
sequence:
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
- conditions:
- condition: state
state: 'on'
sequence:
- conditions:
- condition: state
state: 'on'
sequence:
- conditions:
- condition: state
state: 'on'
sequence:
default: []
- conditions:
- condition: state
state: '25.0'
sequence:
- conditions:
- condition: state
state: '50.0'
sequence:
- conditions:
- condition: state
state: '75.0'
sequence:
- conditions:
- condition: state
state: '100.0'
sequence:
default: []
mode: single
study_fan_speed_set:
sequence:
mode: single
# FAN TEMPLATE
fans:
study_fan:
percentage_template: "{{ states('input_number.study_fan_speed_percentage') }}"
turn_on:
percentage: "{{ 25 }}"
turn_off:
percentage: "{{ 0 }}"
set_percentage:
percentage: "{{ percentage }}"
speed_count: 4
I really wish this could just be fixed in HA. Thanks for this tho!
Hi @jjmuriel I tried your lastest code but keeps giving me this error:Error executing script. Invalid data for call_service at pos 1: expected float for dictionary value @ data[‘value’].
I know you said that it was working for you but not for me. I even setup the helpers correctly but no luck. Regards
This is my full code and now is working without any error:
sequence:
- choose:
- conditions:
- condition: state
state: '0.0'
sequence:
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
data: {}
- conditions:
- condition: state
state: 'on'
sequence:
data: {}
- conditions:
- condition: state
state: 'on'
sequence:
data: {}
- conditions:
- condition: state
state: 'on'
sequence:
data: {}
default: []
data: {}
- conditions:
- condition: state
state: '25.0'
sequence:
data: {}
data: {}
- conditions:
- condition: state
state: '50.0'
sequence:
data: {}
data: {}
- conditions:
- condition: state
state: '75.0'
sequence:
data: {}
data: {}
- conditions:
- condition: state
state: '100.0'
sequence:
data: {}
data: {}
default: []
mode: single
# __________________________________________________
sequence:
data: {}
mode: single
#FAN TEMPLATE (fan.yaml)
fans:
study_fan:
turn_on:
turn_off:
set_percentage:
speed_count: 4
ESPHome code:
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_pass
ap:
ssid: "Fan Speed Controller"
password: !secret ap_pass
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
web_server:
port: 80
# Text sensors with general information.
text_sensor:
# Expose ESPHome version as sensor.
- platform: version
name: Study Smart Fan 1
# Expose WiFi information as sensors.
- platform: wifi_info
ip_address:
name: Study Smart Fan IP
ssid:
name: Study Smart Fan SSID
bssid:
name: Study Smart Fan BSSID
# Sensors with general information.
# Uptime sensor.
- platform: uptime
name: Study Smart Fan Uptime
# WiFi Signal sensor.
- platform: wifi_signal
name: Study Smart Fan WiFi Signal
update_interval: 60s
time:
- platform: sntp
timezone: America/SomePlace
servers: 192.168.X.X
switch:
- platform: gpio
pin: D0
inverted: true
interlock: &interlock_group [speed_one, speed_two, speed_three, speed_four]
interlock_wait_time: 500ms
- platform: gpio
pin: D5
inverted: true
interlock: *interlock_group
- platform: gpio
pin: D6
inverted: true
- platform: gpio
pin: D7
inverted: true
And this is the helper:
I expect this information can help you.
Hi my config looks pretty the same as mine but my esp code is simpler ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=10)
I copied all your code and done the input number but the script called study fan speed set keeps giving me the error expects a float
I feel quite that I can’t make it work even when I full copied your code. Thanks anyway
