I am using an iFan02 and was hoping to use the fan toggle to activate the three speeds of the fan.
Whenever I send a toggle command the speed goes to 0.
This is in my config:
- platform: mqtt
name: "Master Bedroom Fan"
command_topic: "cmnd/sonoff_MBR_fan/FanSpeed"
speed_command_topic: "cmnd/sonoff_MBR_fan/FanSpeed"
state_topic: "stat/sonoff_MBR_fan/RESULT"
speed_state_topic: "stat/sonoff_MBR_fan/RESULT"
state_value_template: >
{% if value_json.FanSpeed is defined %}
{% if value_json.FanSpeed == 0 -%}0{%- elif value_json.FanSpeed > 0 -%}4{%- endif %}
{% else %}
{% if states.fan.master_bedroom_fan.state == 'off' -%}0{%- elif states.fan.master_bedroom_fan.state == 'on' -%}4{%- endif %}
{% endif %}
speed_value_template: "{{ value_json.FanSpeed }}"
availability_topic: tele/sonoff_MBR_fan/LWT
payload_off: "0"
payload_on: "4"
payload_low_speed: "1"
payload_medium_speed: "2"
payload_high_speed: "3"
payload_available: Online
payload_not_available: Offline
speeds:
- off
- low
- medium
- high
