Is there any way to use fast_connect with multiple SSIDs?
For example, I have mine set to first try and connect to the BSSID that I know will be best SNR (due to a long-ago maybe not applicable bug that went by lowest channel) and then if that fails connect to any of the same SSID.
I can’t figure out how to add fast_connect into the mix if its possible at all. Examples put the indent on the same level as the SSID but when I do that I get errors “[fast_connect] is an invalid option for [networks]. Please check the indentation.”.
Also fast_connect connects to first seen not best signal
fast_connect (Optional, boolean): If enabled, directly connects to WiFi network without doing a full scan first. This is required for hidden networks and can significantly improve connection times. Defaults to off. The downside is that this option connects to the first network the ESP sees, even if that network is very far away and better ones are available.
For info, in case someone is interested in the issue: by looking at the logs via serial I found out, with much surprise, that networks (even when specified with a priority value) will NOT skip the full wifi scan.
I hoped that using networks would just connect to the ones I provide, but no, full scan.
Then connects to the one with highest priority.
Right now we have three options in ESPhome:
one SSID, no fast_connect: around 10 seconds for the full wifi scan, best networks chosen
one SSID, with fast_connect: around 1 second or less for wifi connection, but we have no way to be sure it’s the strongest network, we only know “it works” (otherwise a full scan takes place, best network chosen again, and reused the next time)
networks with multiple SSID provided: full scan, then the network provided is used: 10 seconds for the full scan, then our choice.
We miss two options:
fast_connect with delayed full scan, to get quick connect and guarantee of the best network
networkswith fast_connect: fast connect, our choice
