I’m not sure if it’s related, but I had some issues when a package had its own automations and the automation file for the automation editor was empty. I solved this by adding a dummy automation.
FWIW. I also get this error message when trying to restart HA, and I too have a white listed directory for my camera snapshots.
whitelist_external_dirs:
- /share/snapshots
Everything works in HA but for getting this message like the OP. To restart HA after config updates I have to power cycle the RPi. For me I first got these ‘package’ error messages four or five HA updates ago. Been ignoring them ever since.
Same issue. If i include the following snippet, I can’t restart with the above error. Remove it, and everything is fine. This is with or without the single quotes. The path exists, as I’m saving snapshots to it with no problem.
I don’t understand why not much is done or posted about this issue, and since HA 0.75.0 I can’t even use the whitelist dir’s even if I power cycle the RPi now. Loading HA service just hangs until I go into config via SAMBA and remove the whitelist dir.
So my security cameras are effectively down now for pushing realtime images, until whitelisting works again or somebody can fill us in on the tiny bit of information not being said anywhere.
Somebody must know what’s going on for some of us using a whitelist…
