same here.
last 24 hours I have 4467 mentions of the error.
2018-11-28 23:59:07 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on transport TCPTransport (error status in uv_stream_t.read callback)
TimeoutError: [Errno 110] Operation timed out
Mon Jan 21 2019 20:16:52 GMT+0100 (Midden-Europese standaardtijd)
And here: Error doing job: Fatal error on transport TCPTransport (error status in uv_stream_t.read callback)
OSError: [Errno 113] Host is unreachable.
Along with: 08:53 /usr/local/lib/python3.6/site-packages/homeassistant/core.py (ERROR)
Just below this message the log shows an error about trying to reach a kodi mediaplayer. Above it there’s a line about losing connection to a WEMO switch.
I also get a lot of: Client exceeded max pending messages [2]: 512
Unhandled error in exception handler
context: {‘message’: ‘Fatal error on transport TCPTransport (error status in uv_stream_t.read callback)’, ‘exception’: TimeoutError(110, ‘Operation timed out’), ‘transport’: <TCPTransport closed=False reading=False 0x6f617410>, ‘protocol’: <uvloop.loop.SSLProtocol object at 0x6f5cebf0>}
File “uvloop/loop.pyx”, line 2234, in uvloop.loop.Loop.call_exception_handler
File “/usr/local/lib/python3.7/site-packages/homeassistant/core.py”, line 110, in async_loop_exception_handler
“Error doing job: %s”, context[‘message’], **kwargs)
File “/usr/local/lib/python3.7/logging/init.py”, line 1412, in error
self._log(ERROR, msg, args, **kwargs)
File “/usr/local/lib/python3.7/logging/init.py”, line 1519, in _log
self.handle(record)
File “/usr/local/lib/python3.7/logging/init.py”, line 1529, in handle
self.callHandlers(record)
File “/usr/local/lib/python3.7/logging/init.py”, line 1591, in callHandlers
hdlr.handle(record)
File “/usr/local/lib/python3.7/logging/init.py”, line 905, in handle
self.emit(record)
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/system_log/init.py”, line 168, in emit
_figure_out_source(record, stack, self.hass))
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/system_log/init.py”, line 99, in init
self.root_cause = str(traceback.extract_tb(tb)[-1])
IndexError: list index out of range
I have the exact same error mentioning the system_log component:
2019-02-27 21:51:05 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on transport TCPTransport (error status in uv_stream_t.read callback)
2019-02-27 21:51:05 ERROR (MainThread) [asyncio] Unhandled error in exception handler
context: {'message': 'Fatal error on transport TCPTransport (error status in uv_stream_t.read callback)', 'exception': TimeoutError(110, 'Operation timed out'), 'transport': <TCPTransport closed=False reading=False 0x6e9de030>, 'protocol': <uvloop.loop.SSLProtocol object at 0x6e7d7fb0>}
File "uvloop/loop.pyx", line 2234, in uvloop.loop.Loop.call_exception_handler
File "/usr/local/lib/python3.7/site-packages/homeassistant/core.py", line 110, in async_loop_exception_handler
"Error doing job: %s", context['message'], **kwargs)
File "/usr/local/lib/python3.7/logging/__init__.py", line 1412, in error
File "/usr/local/lib/python3.7/logging/__init__.py", line 1519, in _log
self.handle(record)
File "/usr/local/lib/python3.7/logging/__init__.py", line 1529, in handle
File "/usr/local/lib/python3.7/logging/__init__.py", line 1591, in callHandlers
hdlr.handle(record)
File "/usr/local/lib/python3.7/logging/__init__.py", line 905, in handle
self.emit(record)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/system_log/__init__.py", line 168, in emit
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/system_log/__init__.py", line 99, in __init__
It started after I upgraded to 0.88.1 yesterday. I do not use life360 like you do.
I had a Chromecast configured, but I’m not actively using it, so completely removed it. Still got the error afterwards.
I just updated the Github issue, but since not all people check both Github and this topic, I’ll post this here as well:
As mentioned 2 days ago I got this error when I upgraded to 0.88.1. This was from 0.87.1 (so I never used 0.88.0). I upgraded to 0.88.2 and still had this issue.
So, today I decided to downgrade to 0.87.1. No issue at all, not even after an hour. From there I upgraded to 0.88.0 (a version I hadn’t used previously) and after about 20 minutes I received the above error again. From that moment on I started to get that error every 10 minutes on the minute.
So, it’s definitely something introduced in 0.88.0 what is causing this.
I upgraded to 0.89.0 a couple days ago and haven’t seen the above error anymore. However I started seeing the error below every 10 minutes and 3 times at the same time:
Any news on this problem. Today I saw my Hassio UI constantly reconnecting, and when I look at the logs I can see only this error. :\ I haven’t installed/edited/added anything from months … :\
I am having the same error once per day the same time since 0.93: Tue Jun 18 2019 00:31:11 GMT+1000 (Australian Eastern Standard Time) Error doing job: Fatal error on transport TCPTransport (error status in uv_stream_t.read callback) TimeoutError: [Errno 110] Operation timed out
But no other errors and everything seems working OK, so this is weird
