I still get several fatal errors on TCP transport, who are still not fixed…
Sat Dec 16 2017 02:14:34 GMT+0100 (Romance (standaardtijd))
Error doing job: Fatal error on transport TCPTransport (error status in uv_stream_t.read callback)
TimeoutError: [Errno 110] Operation timed out
ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on transport TCPTransport (error status in uv_stream_t.read callback)
OSError: [Errno 113] Host is unreachable
and
Everything runs fine here.
Running:
Home Assistant: 0.61.1
Supervisor: 0.83
Hardware: Pi3
same issue with HA 0.70.0 inside docker - not using Hassio
2018-06-11 15:19:27 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on transport TCPTransport (error status in uv_stream_t.read callback)
I too have the issue. Well over 6 months this issue has been reported with no know resolution? I had DarkSky enabled but with the logs filling up with errors specific to DS, I disabled it. I continue to see the following:
Also:
Error connecting to Ecobee. Possible connectivity outage.
Hass.io .71 (attempts to upgrade to .72 timeout)
R3Bpi
