I have following error when flashing my ESP8266 nodemcuv3. I used ESPHome Flasher through a usb connnection.
My yaml code is around 750 lines. Is there a limit?
ANyone has an idea what could be the cause?
Using ‘/dev/cu.usbserial-1410’ as serial port.
Showing logs:
[00:32:10]
Serial port closed!
[00:32:10]Fa ets Ja013,rst cause:, boot mode:(3,6)
[00:32:10]
[00:32:10]wdt reset
[00:32:10]load 0x4010f000, len 3584, room 16
[00:32:10]tail 0
[00:32:10]chksum 0xb0
[00:32:10]csum 0xb0
[00:32:10]v2843a5ac
[00:32:10]~ld
[00:32:10]
[00:32:10]SDK:2.2.2-dev(38a443e)/Core:2.7.3-3-g2843a5ac=20703003/lwIP:STABLE-2_1_2_RELEASE/glue:1.2-30-g92add50/BearSSL:5c771be
[00:32:10][I][logger:166]: Log initialized
[00:32:10][C][ota:366]: There have been 2 suspected unsuccessful boot attempts.
[00:32:10]Fatal exception 29(StoreProhibitedCause):
[00:32:19]Fa
[00:32:19] ets Jan 8 2013,rst cause:4, boot mode:(3,6)
[00:32:19]
[00:32:19]wdt reset
[00:32:19]load 0x4010f000, len 3584, room 16
[00:32:19]tail 0
[00:32:19]chksum 0xb0
[00:32:19]csum 0xb0
[00:32:19]v2843a5ac
[00:32:19]~ld
[00:32:19]
[00:32:19]SDK:2.2.2-dev(38a443e)/Core:2.7.3-3-g2843a5ac=20703003/lwIP:STABLE-2_1_2_RELEASE/glue:1.2-30-g92add50/BearSSL:5c771be
[00:32:19][I][logger:166]: Log initialized
[00:32:19][C][ota:366]: There have been 3 suspected unsuccessful boot attempts.
[00:32:19]Fatal exception 29(StoreProhibitedCause):
[00:32:27]Fa
[00:32:27] ets Jan 8 2013,rst cause:4, boot mode:(3,6)
[00:32:27]
[00:32:27]wdt reset
[00:32:27]load 0x4010f000, len 3584, room 16
[00:32:27]tail 0
[00:32:27]chksum 0xb0
[00:32:27]csum 0xb0
[00:32:27]v2843a5ac
[00:32:27]~ld
[00:32:27]
[00:32:27]SDK:2.2.2-dev(38a443e)/Core:2.7.3-3-g2843a5ac=20703003/lwIP:STABLE-2_1_2_RELEASE/glue:1.2-30-g92add50/BearSSL:5c771be
[00:32:27][I][logger:166]: Log initialized
[00:32:27][C][ota:366]: There have been 4 suspected unsuccessful boot attempts.
[00:32:27]Fatal exception 29(StoreProhibitedCause):
