Fatal: not a git repository (or any parent up to mount point /) after update esphome
hi
After updating esphome, I get this error when I install the program on esp32s3.
INFO ESPHome 2025.8.0b1
INFO Reading configuration /config/esphome/21-roundlvgl.yaml...
WARNING 120MHz PSRAM in octal mode is an experimental feature - use at your own risk
INFO Generating C++ source...
WARNING Using experimental features in ESP-IDF may result in unexpected failures.
INFO Compiling app...
Processing 21-roundlvgl (board: esp32-s3-devkitc-1; framework: espidf; platform: https://github.com/pioarduino/platform-espressif32/releases/download/54.03.21-2/platform-espressif32.zip)
INFO Package configuration completed successfully
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
 - framework-espidf @ 3.50402.0 (5.4.2)
 - tool-cmake @ 3.30.2
 - tool-esp-rom-elfs @ 2024.10.11
 - tool-esptoolpy @ 5.0.2
 - tool-mklittlefs @ 3.2.0
 - tool-ninja @ 1.13.1
 - tool-scons @ 4.40801.0 (4.8.1)
 - toolchain-esp32ulp @ 2.35.0-20220830
 - toolchain-xtensa-esp-elf @ 14.2.0+20241119
Reading CMake configuration...
-- git rev-parse returned 'fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).'
-- The C compiler identification is unknown
-- The CXX compiler identification is unknown
-- The ASM compiler identification is unknown
-- Found assembler: xtensa-esp32s3-elf-gcc
-- Warning: Did not find file Compiler/-ASM
-- Configuring incomplete, errors occurred!
CMake Error at /data/cache/platformio/packages/framework-espidf/tools/cmake/project.cmake:571 (__project):
  The CMAKE_C_COMPILER:
  is not a full path and was not found in the PATH.
  Tell CMake where to find the compiler by setting either the environment
  variable "CC" or the CMake cache entry CMAKE_C_COMPILER to the full path to
  the compiler, or to the compiler name if it is in the PATH.
Call Stack (most recent call first):
  CMakeLists.txt:3 (project)
  The CMAKE_CXX_COMPILER:
    xtensa-esp32s3-elf-g++
  variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
  to the compiler, or to the compiler name if it is in the PATH.
  The CMAKE_ASM_COMPILER:
  variable "ASM" or the CMake cache entry CMAKE_ASM_COMPILER to the full path
========================== [FAILED] Took 5.74 seconds ==========================
You are running a beta version. Better report in EspHome’s github.
I tested all versions and I still have the same problem.
INFO ESPHome 2025.7.5
Processing 21-roundlvgl (board: esp32-s3-devkitc-1; framework: espidf; platform: https://github.com/pioarduino/platform-espressif32/releases/download/53.03.13/platform-espressif32.zip)
 - framework-espidf @ 3.50302.0 (5.3.2)
 - tool-esptoolpy @ 4.8.6
 - tool-ninja @ 1.10.2
 - tool-riscv32-esp-elf-gdb @ 14.2.0+20240403
 - tool-xtensa-esp-elf-gdb @ 14.2.0+20240403
 - toolchain-riscv32-esp @ 13.2.0+20240530
 - toolchain-xtensa-esp-elf @ 13.2.0+20240530
-- Building ESP-IDF components for target esp32s3
CMake Error at /data/cache/platformio/packages/framework-espidf/tools/cmake/build.cmake:552 (message):
  /root/.platformio/penv/.espidf-5.3.2/bin/python: Error while finding module
  specification for 'idf_component_manager.prepare_components'
  (ModuleNotFoundError: No module named 'idf_component_manager')
That error indicates your platform.io install is not correct. Normally, esphome installs it for you, but only if it isn’t already there. Since it is there, but apparently corrupted, you will likely need to do something different. I would just delete the platformio folder and see what that does.
I didn’t find anything on the “official” way to fix an error like this.
Thanks for your advice. I uninstalled the beta version and just worked with the regular version and my problem was solved.
