Recently I got an error with some integrations setting up. The log tells me there is some issue with: FATAL: password authentication failed for user “home-assistant”
What is the issue there?
2022-03-18 08:53:27 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (psycopg2.OperationalError) FATAL: password authentication failed for user "home-assistant"
(Background on this error at: https://sqlalche.me/e/14/e3q8) (retrying in 3 seconds)
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 3243, in _wrap_pool_connect
return fn()
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/pool/base.py", line 310, in connect
return _ConnectionFairy._checkout(self)
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/pool/base.py", line 868, in _checkout
fairy = _ConnectionRecord.checkout(pool)
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/pool/base.py", line 476, in checkout
rec = pool._do_get()
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/pool/impl.py", line 146, in _do_get
self._dec_overflow()
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/util/langhelpers.py", line 70, in __exit__
compat.raise_(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/util/compat.py", line 207, in raise_
raise exception
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/pool/impl.py", line 143, in _do_get
return self._create_connection()
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/pool/base.py", line 256, in _create_connection
return _ConnectionRecord(self)
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/pool/base.py", line 371, in __init__
self.__connect()
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/pool/base.py", line 666, in __connect
pool.logger.debug("Error on connect(): %s", e)
compat.raise_(
raise exception
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/pool/base.py", line 661, in __connect
self.dbapi_connection = connection = pool._invoke_creator(self)
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/create.py", line 590, in connect
return dialect.connect(*cargs, **cparams)
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/default.py", line 584, in connect
return self.dbapi.connect(*cargs, **cparams)
File "/usr/local/lib/python3.9/site-packages/psycopg2/__init__.py", line 122, in connect
conn = _connect(dsn, connection_factory=connection_factory, **kwasync)
