I recently updated my Hassio installation to 103.5.
This morning I noticed that my installation could no longer contact external url’s (such as the weather information). Then I tried rebooting my system, but it will no longer start.
Checking the logs I see the following:
Error: Fatal Python error: initsite: Failed to import the site module
Error processing line 1 of /usr/local/lib/python3.7/site-packages/google_api_core-1.15.0-py3.8-nspkg.pth:
File "/usr/local/lib/python3.7/site.py", line 168, in addpackage
exec(line)
File "<string>", line 1, in <module>
File "/usr/local/lib/python3.7/importlib/util.py", line 14, in <module>
from contextlib import contextmanager
File "/usr/local/lib/python3.7/contextlib.py", line 6, in <module>
from functools import wraps
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 724, in exec_module
File "<frozen importlib._bootstrap_external>", line 857, in get_code
File "<frozen importlib._bootstrap_external>", line 525, in _compile_bytecode
ValueError: bad marshal data (unknown type code)
File "/usr/local/lib/python3.7/site.py", line 579, in <module>
main()
File "/usr/local/lib/python3.7/site.py", line 566, in main
known_paths = addsitepackages(known_paths)
File "/usr/local/lib/python3.7/site.py", line 349, in addsitepackages
addsitedir(sitedir, known_paths)
File "/usr/local/lib/python3.7/site.py", line 207, in addsitedir
addpackage(sitedir, name, known_paths)
File "/usr/local/lib/python3.7/site.py", line 178, in addpackage
import traceback
File "/usr/local/lib/python3.7/traceback.py", line 5, in <module>
import linecache
File "/usr/local/lib/python3.7/linecache.py", line 8, in <module>
import functools
This is my setup info:
~ $ hassio homeassistant info
arch: armv7
boot: true
custom: false
image: homeassistant/raspberrypi3-homeassistant
ip_address: 172.30.32.1
last_version: 0.103.5
machine: raspberrypi3
port: 8123
ssl: true
version: 0.103.5
wait_boot: 600
watchdog: true
Any suggestions on how to solve this?
Thanks in advance.
Bart
