Fatal python error when loading Frigate
This thread is closed, it turns out that the AMD E-350 CPU that I’m using doesn’t support the AVX instruction set that Frigate uses. So I’m switching to Scrypted instead.
My Frigate addon won’t start. I receive a spanning wheel and a message asking if I want to restart.
I’m following these two sets of instructions to install Frigate:
Installing MQTT
installing Frigate
I’ve confirmed that my camera’s RTSP details are correct by putting the path into VLC
When I try to start the Frigate addon I receive the following error message
2023-11-17 18:04:05.567914897  Fatal Python error: Illegal instruction
Here is the complete log file
s6-rc: info: service legacy-services: starting
2023-11-17 18:04:00.070092580  [INFO] Starting NGINX...
s6-rc: info: service legacy-services successfully started
2023-11-17 18:04:00.303477814  [INFO] Got IP address from supervisor: 192.168.0.79
2023-11-17 18:04:00.538311802  [INFO] Got WebRTC port from supervisor: 8555
2023-11-17 18:04:01.894605068  [INFO] Starting go2rtc...
2023-11-17 18:04:02.111008443  18:04:02.110 INF go2rtc version 1.2.0 linux/amd64
2023-11-17 18:04:02.113574324  18:04:02.113 INF [api] listen addr=:1984
2023-11-17 18:04:02.116067550  18:04:02.115 INF [rtsp] listen addr=:8554
2023-11-17 18:04:02.118752678  18:04:02.118 INF [srtp] listen addr=:8443
2023-11-17 18:04:02.121324341  18:04:02.121 INF [webrtc] listen addr=:8555
2023-11-17 18:04:05.567936929
2023-11-17 18:04:05.567954426  Current thread 0x00007fd008f70740 (most recent call first):
2023-11-17 18:04:05.567971967    File "<frozen importlib._bootstrap>", line 228 in _call_with_frames_removed
2023-11-17 18:04:05.568076762    File "<frozen importlib._bootstrap_external>", line 1108 in create_module
2023-11-17 18:04:05.568093588    File "<frozen importlib._bootstrap>", line 565 in module_from_spec
2023-11-17 18:04:05.568106668    File "<frozen importlib._bootstrap>", line 666 in _load_unlocked
2023-11-17 18:04:05.568119777    File "<frozen importlib._bootstrap>", line 986 in _find_and_load_unlocked
2023-11-17 18:04:05.568165322    File "<frozen importlib._bootstrap>", line 1007 in _find_and_load
2023-11-17 18:04:05.568210015    File "<frozen importlib._bootstrap>", line 228 in _call_with_frames_removed
2023-11-17 18:04:05.568266748    File "<frozen importlib._bootstrap>", line 1058 in _handle_fromlist
2023-11-17 18:04:05.568357755    File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 41 in <module>
2023-11-17 18:04:05.568427019    File "<frozen importlib._bootstrap>", line 228 in _call_with_frames_removed
2023-11-17 18:04:05.568493382    File "<frozen importlib._bootstrap_external>", line 790 in exec_module
2023-11-17 18:04:05.570800357    File "<frozen importlib._bootstrap>", line 680 in _load_unlocked
2023-11-17 18:04:05.570820934    File "<frozen importlib._bootstrap>", line 986 in _find_and_load_unlocked
2023-11-17 18:04:05.570833943    File "<frozen importlib._bootstrap>", line 1007 in _find_and_load
2023-11-17 18:04:05.570847315    File "/opt/frigate/frigate/detectors/plugins/cpu_tfl.py", line 10 in <module>
2023-11-17 18:04:05.570860440    File "<frozen importlib._bootstrap>", line 228 in _call_with_frames_removed
2023-11-17 18:04:05.570882478    File "<frozen importlib._bootstrap_external>", line 790 in exec_module
2023-11-17 18:04:05.571010909    File "<frozen importlib._bootstrap>", line 680 in _load_unlocked
2023-11-17 18:04:05.571028395    File "<frozen importlib._bootstrap>", line 986 in _find_and_load_unlocked
2023-11-17 18:04:05.571041398    File "<frozen importlib._bootstrap>", line 1007 in _find_and_load
2023-11-17 18:04:05.574486745    File "<frozen importlib._bootstrap>", line 1030 in _gcd_import
2023-11-17 18:04:05.576267588    File "/usr/lib/python3.9/importlib/__init__.py", line 127 in import_module
2023-11-17 18:04:05.576339363    File "/opt/frigate/frigate/detectors/detector_types.py", line 25 in <module>
2023-11-17 18:04:05.577583823    File "<frozen importlib._bootstrap>", line 228 in _call_with_frames_removed
2023-11-17 18:04:05.577598213    File "<frozen importlib._bootstrap_external>", line 790 in exec_module
2023-11-17 18:04:05.577605146    File "<frozen importlib._bootstrap>", line 680 in _load_unlocked
2023-11-17 18:04:05.577611971    File "<frozen importlib._bootstrap>", line 986 in _find_and_load_unlocked
2023-11-17 18:04:05.577618481    File "<frozen importlib._bootstrap>", line 1007 in _find_and_load
2023-11-17 18:04:05.577625115    File "/opt/frigate/frigate/detectors/__init__.py", line 9 in <module>
2023-11-17 18:04:05.577631765    File "<frozen importlib._bootstrap>", line 228 in _call_with_frames_removed
2023-11-17 18:04:05.577638240    File "<frozen importlib._bootstrap_external>", line 790 in exec_module
2023-11-17 18:04:05.577644596    File "<frozen importlib._bootstrap>", line 680 in _load_unlocked
2023-11-17 18:04:05.577651111    File "<frozen importlib._bootstrap>", line 986 in _find_and_load_unlocked
2023-11-17 18:04:05.577793677    File "<frozen importlib._bootstrap>", line 1007 in _find_and_load
2023-11-17 18:04:05.577802014    File "/opt/frigate/frigate/config.py", line 36 in <module>
2023-11-17 18:04:05.577873854    File "<frozen importlib._bootstrap>", line 228 in _call_with_frames_removed
2023-11-17 18:04:05.577882577    File "<frozen importlib._bootstrap_external>", line 790 in exec_module
2023-11-17 18:04:05.577889617    File "<frozen importlib._bootstrap>", line 680 in _load_unlocked
2023-11-17 18:04:05.577896127    File "<frozen importlib._bootstrap>", line 986 in _find_and_load_unlocked
2023-11-17 18:04:05.577902708    File "<frozen importlib._bootstrap>", line 1007 in _find_and_load
2023-11-17 18:04:05.577909031    File "/opt/frigate/frigate/comms/dispatcher.py", line 9 in <module>
2023-11-17 18:04:05.577983300    File "<frozen importlib._bootstrap>", line 228 in _call_with_frames_removed
2023-11-17 18:04:05.578813858    File "<frozen importlib._bootstrap_external>", line 790 in exec_module
2023-11-17 18:04:05.578825093    File "<frozen importlib._bootstrap>", line 680 in _load_unlocked
2023-11-17 18:04:05.578831220    File "<frozen importlib._bootstrap>", line 986 in _find_and_load_unlocked
2023-11-17 18:04:05.578837186    File "<frozen importlib._bootstrap>", line 1007 in _find_and_load
2023-11-17 18:04:05.578843072    File "/opt/frigate/frigate/app.py", line 17 in <module>
2023-11-17 18:04:05.579132303    File "<frozen importlib._bootstrap>", line 228 in _call_with_frames_removed
2023-11-17 18:04:05.579142580    File "<frozen importlib._bootstrap_external>", line 790 in exec_module
2023-11-17 18:04:05.579148968    File "<frozen importlib._bootstrap>", line 680 in _load_unlocked
2023-11-17 18:04:05.579155470    File "<frozen importlib._bootstrap>", line 986 in _find_and_load_unlocked
2023-11-17 18:04:05.579161787    File "<frozen importlib._bootstrap>", line 1007 in _find_and_load
2023-11-17 18:04:05.579168055    File "/opt/frigate/frigate/__main__.py", line 9 in <module>
2023-11-17 18:04:05.579174068    File "/usr/lib/python3.9/runpy.py", line 87 in _run_code
2023-11-17 18:04:05.579180435    File "/usr/lib/python3.9/runpy.py", line 197 in _run_module_as_main
2023-11-17 18:04:06.304330707  [INFO] Service Frigate exited with code 256 (by signal 4)
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service nginx: stopping
s6-rc: info: service go2rtc-healthcheck: stopping
2023-11-17 18:04:06.352088889  [INFO] The go2rtc-healthcheck service exited with code 256 (by signal 15)
s6-rc: info: service go2rtc-healthcheck successfully stopped
2023-11-17 18:04:06.372339428  [INFO] Service NGINX exited with code 0 (by signal 0)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service nginx-log: stopping
s6-rc: info: service frigate: stopping
s6-rc: info: service frigate successfully stopped
s6-rc: info: service go2rtc: stopping
s6-rc: info: service frigate-log: stopping
s6-rc: info: service nginx-log successfully stopped
2023-11-17 18:04:06.393752326  exit OK
s6-rc: info: service frigate-log successfully stopped
2023-11-17 18:04:06.412844834  [INFO] The go2rtc service exited with code 0 (by signal 0)
s6-rc: info: service go2rtc successfully stopped
s6-rc: info: service go2rtc-log: stopping
s6-rc: info: service go2rtc-log successfully stopped
s6-rc: info: service log-prepare: stopping
s6-rc: info: service s6rc-fdholder: stopping
s6-rc: info: service log-prepare successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service s6rc-fdholder successfully stopped
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
On reboot\restart I receive multiple Frigate related error messages
23-11-17 18:03:10 INFO (MainThread) [supervisor.api.middleware.security] /network/interface/default/info access from ccab4aaf_frigate
23-11-17 18:03:21 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Frigate is failed, restarting...
23-11-17 18:03:21 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_ccab4aaf_frigate application
23-11-17 18:03:22 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/blakeblackshear/frigate with version 0.12.1
23-11-17 18:03:22 INFO (MainThread) [supervisor.api.middleware.security] /network/interface/default/info access from ccab4aaf_frigate
23-11-17 18:03:33 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Frigate is failed, restarting...
23-11-17 18:03:33 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_ccab4aaf_frigate application
23-11-17 18:03:34 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/blakeblackshear/frigate with version 0.12.1
23-11-17 18:03:35 INFO (MainThread) [supervisor.api.middleware.security] /network/interface/default/info access from ccab4aaf_frigate
23-11-17 18:03:45 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Frigate is failed, restarting...
23-11-17 18:03:46 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_ccab4aaf_frigate application
23-11-17 18:03:47 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/blakeblackshear/frigate with version 0.12.1
23-11-17 18:03:47 INFO (MainThread) [supervisor.api.middleware.security] /network/interface/default/info access from ccab4aaf_frigate
23-11-17 18:03:49 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:03:56 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.4:5000 ssl:default [Connect call failed ('172.30.33.4', 5000)]
23-11-17 18:03:58 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Frigate is failed, restarting...
23-11-17 18:03:58 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_ccab4aaf_frigate application
23-11-17 18:03:59 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/blakeblackshear/frigate with version 0.12.1
23-11-17 18:04:00 INFO (MainThread) [supervisor.api.middleware.security] /network/interface/default/info access from ccab4aaf_frigate
23-11-17 18:04:10 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-318663' coro=<Addon.watchdog_container() done, defined at /usr/src/supervisor/supervisor/addons/addon.py:1327> exception=AddonsJobError('Rate limit exceeded, more than 10 calls in 0:30:00')>
  File "/usr/src/supervisor/supervisor/addons/addon.py", line 1341, in watchdog_container
    await self._restart_after_problem(event.state)
  File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 276, in wrapper
    raise on_condition(
supervisor.exceptions.AddonsJobError: Rate limit exceeded, more than 10 calls in 0:30:00
23-11-17 18:05:10 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:06:29 ERROR (SyncWorker_4) [supervisor.docker.manager] Container addon_ccab4aaf_frigate is not running
23-11-17 18:06:30 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:07:42 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_ccab4aaf_frigate application
23-11-17 18:07:43 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/blakeblackshear/frigate with version 0.12.1
23-11-17 18:07:43 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.4:5000 ssl:default [Connect call failed ('172.30.33.4', 5000)]
23-11-17 18:07:43 INFO (MainThread) [supervisor.api.middleware.security] /network/interface/default/info access from ccab4aaf_frigate
23-11-17 18:07:50 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:07:54 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-319057' coro=<Addon.watchdog_container() done, defined at /usr/src/supervisor/supervisor/addons/addon.py:1327> exception=AddonsJobError('Rate limit exceeded, more than 10 calls in 0:30:00')>
    raise on_condition(
23-11-17 18:09:11 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:10:31 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:10:46 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.4:5000 ssl:default [Connect call failed ('172.30.33.4', 5000)]
Deleted because the log was too long
23-11-17 18:17:14 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:18:34 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:19:50 INFO (SyncWorker_0) [supervisor.docker.manager] Restarting homeassistant
23-11-17 18:20:15 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
23-11-17 18:20:24 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-11-17 18:20:25 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-11-17 18:20:26 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to NOT_RUNNING
23-11-17 18:20:29 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
23-11-17 18:20:29 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
23-11-17 18:20:29 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
23-11-17 18:20:29 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/blakeblackshear/frigate-hass-addons repository
23-11-17 18:20:29 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-11-17 18:20:31 WARNING (SyncWorker_3) [supervisor.addons.validate] Add-on have full device access, and selective device access in the configuration. Please report this to the maintainer of Frigate (Full Access) Beta (0.13.0)
23-11-17 18:20:31 WARNING (SyncWorker_2) [supervisor.addons.validate] Add-on have full device access, and selective device access in the configuration. Please report this to the maintainer of Frigate (Full Access) Beta (0.13.0)
23-11-17 18:20:32 INFO (MainThread) [supervisor.store] Loading add-ons from store: 76 all - 0 new - 0 remove
23-11-17 18:21:04 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:21:05 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:21:06 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:21:07 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to RUNNING
23-11-17 18:21:07 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
23-11-17 18:21:11 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:21:21 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:21:42 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:22:22 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:23:42 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:25:03 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:26:12 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-11-17 18:26:23 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:27:43 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:29:04 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:30:24 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:31:44 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:33:05 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:34:25 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:35:45 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:37:06 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:38:26 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:39:46 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:41:07 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:42:27 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:43:48 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:45:08 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:46:29 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:47:49 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:49:10 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:50:30 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:51:51 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
23-11-17 18:53:11 ERROR (MainThread) [supervisor.addons.addon] Add-on core_silabs_multiprotocol has invalid options: Missing required option 'device' in Silicon Labs Multiprotocol (core_silabs_multiprotocol). Got {'device': None, 'baudrate': '460800', 'flow_control': True, 'autoflash_firmware': True, 'cpcd_trace': False, 'otbr_enable': True, 'otbr_log_level': 'notice', 'otbr_firewall': True}
This is my Frigate yml files, I’ve confirmed that the rtsp string is correct in VLC.
mqtt:
  host: 192.168.0.79
  user: MQTT_USER
  password: MQTT_PASSWORD
cameras:
  Front_Room_Camera_Besder1:
    ffmpeg:
      inputs:
        - path: rtsp://192.168.0.43:554/user=USER&password=PASSWORD&channel=1&stream=0.sdp?
          roles:
            - detect
    width: 1280
    height: 720
    fps: 6
detectors:
  cpu1:
    type: cpu
  cpu2:
    type: cpu
Hi
I am having the exact same errors
i do have another completly seperate ha instalation on a different micro pc and frigate is running ok on that
Do you have any clue that might help figure out where the error is?
For example, should I be looking in the frigate.yml, or the MQTT settings, or in the frigate add on settings.
I think that the python message simply means that something isn’t configured correctly.
this means that your computer does not support AVX instructions which are required for frigate
Is that a problem with my hardware not being supported, or my software environment?
I’m using an AMD E-350 CPU, which I’m pretty certain supports AVX.
Well … apparently it doesn’t.
What are my alternatives to frigate?
it’s an issue with your hardware not supporting the AVX instruction
Requiring AVX is not something specific to frigate, they are required for object detection via tflite. There is a community led addon that supports non-avx devices but this will be especially slow support for old hardware with no AVX · Issue #49 · blakeblackshear/frigate · GitHub
My problem was that my CPU isn’t compatible with Frigate, could this be the solution to your problem as well?
I’m using an Zotac AD02 with an AMD E-350 CPU that I recycled from an old Kodi box.
It seems to be that, runs everything elese bar Frigate , as i said i have another Wyse running frigate.
Is it a 32 bit system?
No 64 bit
https://www.dell.com/support/manuals/en-uk/wyse-5070-thin-client/5070_extd_ug/system-specifications?guid=guid-9c52cf63-fcd7-4bb7-b70e-f9107c95ec97&lang=en-us
If it’s 64 bit and supports AVX, and you haven’t turned it off some how in the BIOS, then we’re probably having different problems.
I’m afraid that I’m not able to help you very much as I know nothing about Python.
