Yesterday I upgraded (my fault) to 0.83 from 0.82.1 and I get a lot of issues.
I’ve tried to downgrade back to 0.82.1 and now Hassio is not starting anymore.
I can access to internal terminal, but no samba.
Now I have got a new SD card and restore a snapshot from two day ago, but something is missing, probably, because I get a lot of misconfiguration and errors.
How can I access the old SD card from Windows/Linux/Mac to copy all the files in various config/addons/share folder to the new SD card?
The safest (but most long winded ) secure your old configuration. Then create a new install on a new sd card . Get it working so you can log in . Install SSH add in and then samba . Get them working. Take a snapshot . Test it ! . Then start copying your configuration files back. Testing each time
I have the same issue after update, did it get it resolved without reinstalling everything?
My loggfile:
2018-12-01 15:04:20 ERROR (MainThread) [aiohttp.server] Error handling request
File “/usr/local/lib/python3.6/site-packages/aiohttp/web_protocol.py”, line 390, in start
resp = await self._request_handler(request)
File “/usr/local/lib/python3.6/site-packages/aiohttp/web_app.py”, line 366, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.6/site-packages/aiohttp/web_middlewares.py”, line 106, in impl
return await handler(request)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/http/static.py”, line 66, in staticresource_middleware
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/http/real_ip.py”, line 34, in real_ip_middleware
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/http/ban.py”, line 66, in ban_middleware
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/http/auth.py”, line 97, in auth_middleware
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/http/view.py”, line 113, in handle
result = await result
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/http/ban.py”, line 76, in handle_req
resp = await func(view, request, *args, **kwargs)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/auth/init.py”, line 258, in post
hass, data, str(request[KEY_REAL_IP]))
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/auth/init.py”, line 346, in _async_handle_refresh_token
refresh_token = await hass.auth.async_get_refresh_token_by_token(token)
File “/usr/local/lib/python3.6/site-packages/homeassistant/auth/init.py”, line 330, in async_get_refresh_token_by_token
return await self._store.async_get_refresh_token_by_token(token)
File “/usr/local/lib/python3.6/site-packages/homeassistant/auth/auth_store.py”, line 204, in async_get_refresh_token_by_token
await self._async_load()
File “/usr/local/lib/python3.6/site-packages/homeassistant/auth/auth_store.py”, line 247, in _async_load
name=group_dict[‘name’],
KeyError: ‘name’
