Me too with WiFi and I also lean in that direction (preferring wifi) but my home is older so I have adventures with disintegrating cloth insulation as well as alot of places with no neutral.
For simplicity of protocols and tighter control I prefer to stick with WiFi (so not Zigbee or ZWave interference issues to ever figure out stumbling around)
Make all devices static IP’s as you add them and make sure each is properly named in your router to stop any confusion. Many devices listed below (mainly Shelly) each have their own onboard web ui so I have a set of shortcuts to them all (those ip addresses)
Interesting title to this thread as the very best brand of light switch/es (not dimmers) are those that are completle invisible (hidden) and still allow the person to interact physically with the old hardware exactly as before, while still seamlessly offering remote control)…
Many of my automations rely upon sensing motion. I have motion snesors from Yolink, but that requires a hub (I hate having a hub) which talks to Yolink servers and your HA instance only talks to the Yolink servers (ugh). They are also working on a local hub but the check is in the mail if you know what I mean. They are able to keep the latency low by keeping mqtt pipes open between your hub and their servers, as well as your HA instance and their servers. However if your intenet connection is solid, that might be a good selection for SOME of your sensors - as Yolink offers one thing that no other automation I can find for Home assistant - Virtualarm. Virtualarm is a service for $9/month that you can set up with your yolkink account which will call you when a sensor is triggered (if you want) - and if you do not respond, then they call the police and/or fire department. My wife microwaved a potato twice by mistake and it actually caught of fire, setting my yolink fire detectors off (which do stil make noise if there is no internet connection) - so we did not hear our cell phones rining - and a fire truck was outside my home in 5 minutes! (for fire they do not call, they just show up.) So I have that turned on for leak sensors and home alarm related sensors.
My favorite integration with HA for sensors are Shelly. I swear by Shelly, you CANNOT go wrong with them. Their WiFi connection is ROCK SOLID. They stand by their products and will replace them if defective. They are victims of their own success as their business has just mushroomed so much that there are now delays when putting in support tickets etc. Note however, now that they have grown to be a large firm, the CEO and founder even answrers many questions on their main support forum which is actually a facebook group here. So, if you have a question or issue - it is likely the CEO will answr you directly as he is a smart techie geek as well. How freaking great is that? His name is Dimitar Dimitrov - you will see his posts and answers all over the place there. Be respectful, he doesn’t have to do that, don’t pester him
Almost every one of their products has their own web site interface (except for the BLU line of products) and they can be local only (and work with no issue) or also connected to the internet (mine are all connected to the internet for convenience but each has a unique 30 difgit password). They have a massive number of configuration options all available within the Shelly app, Home assistant, or each device’s web page.
Picture of a shelly relay for a ceiling fluorescent light fixture. It is configured such that you can turn the light on or off remotely through HA and at the same time physically (meaning if it is off physically you can still turn the light on remotely - and then off physically again - or visa-versa - works seamlessly). As this is in my basement I didn’t bother hiding the shelly, this setup is for convenience if I ever have to replace the unit (nothing lasts forever):
Notice at the end of each cable are ferrules - which is the cleanest and safestr, best way to connect to a shelly, so you will want one of these (forgive the messy workbench)
and
Lastly you will want extra wiring and a cheapie electical multimeter and extra (threaded so they can be bent many times) wires of the maximum size to fit into the ferrules (you may have to remove a couple of the threads)
Sometimes shelly would throw one in your order as a gift:
This is a Shelly Motion 2, (which are out of stock due to a chip shortage but you can find them elsewhere (I got 12 of them on absoluteautomaton.com. Their batteries last a full year ans they can sense eyes blinking even, mine sense motion from 20 feet away (this also has 256 levels of sensitivity, etc.
But amazingly, this new tiny device from Shelly (below) is actually a motion sensor that reacts even more quickly supposedly - than the above Shelly Motion 2 - this is a photo of a Shelly BLU Motion (in the blue circle, I pulled back to show you how small it is), motion sensor hidden in a bathroom above a toilet seat. The Shelly BLU Motion is amazeballs. The battery lasts 5 YEARS and it is tiny - and very sensitive. The (previous picture) Shelly Motion 2 goes to sleep and it’s only very minor latency is to wake up and reinitiate the WiFi connection - which it does very quickly with that custom chip (that has the shortage). With the Shellty BLU Motion below however, and this is the pure genious of this device (alro relying on the BT Home standard with BLE so the battery lasts a very long time), it is actually paired by bluetooth to (if you like) one or more or all of your Shelly (gen 2) devices in your home - which are already conected with an acitve connection to your network - so any mnotion as soon as it is detected is sent to ALL of your other shelly gen 2 relays so the notification ends up getting back to your Home Assistant almost instantly - pure genious!
