Feature request: alarm clock
It would be useful to have the existing alarms in home assistant as switches and have the ability to turn them on or off
Could you describe it more, and i will like to help you :slight_smile:
In IOS, in the Clock app, you can have many alarms comfigured. Each of them can be enabled or disabled using a switch inside the app.
I’d find useful having each alarm represented in home assistant with a switch (or input_boolean) and the ability to enable or disable them or at least a specific service to turn them on or off.
In this way, for example, a workday/holiday scheduler inside homeassistant can also set the alarms for the next day.
Allright, that could be nice to have.
But i found it complicated.
So i use a speaker for the alarm sound.
Easy, and keep it simple, if we can.
