Home Assistant is a wonderful platform, but it has started failing in the last 6 months or so, where it would just randomly crash and restart (which takes 20-40 minutes)
It would be useful if there was a way to identify the reason of the restart instead of just logging things like this:
(it finished restarting at 10:22 and it had been unreachable for at least the 20 minutes before that)
2021-05-29 10:01:24 WARNING (MainThread) [homeassistant.components.sensor] Updating command_line sensor took longer than the scheduled update interval 0:00:03
2021-05-29 10:01:24 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.ping_eolo is taking over 10 seconds
2021-05-29 10:01:50 WARNING (MainThread) [homeassistant.components.sensor] Updating command_line sensor took longer than the scheduled update interval 0:00:03
2021-05-29 10:01:50 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ping binary_sensor took longer than the scheduled update interval 0:00:30
2021-05-29 10:02:35 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [140416179852192] Disconnected: Did not receive auth message within 10 seconds
2021-05-29 10:02:35 WARNING (MainThread) [homeassistant.components.sensor] Updating command_line sensor took longer than the scheduled update interval 0:00:03
2021-05-29 10:02:35 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating workday binary_sensor took longer than the scheduled update interval 0:00:30
2021-05-29 10:02:47 WARNING (MainThread) [homeassistant.components.sensor] Updating command_line sensor took longer than the scheduled update interval 0:00:03
2021-05-29 10:03:00 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [140417517316944] Disconnected: Did not receive auth message within 10 seconds
2021-05-29 10:03:00 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Timeout sending notification to https://mobile-apps.home-assistant.io/api/sendPushNotification
2021-05-29 10:03:06 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ping binary_sensor took longer than the scheduled update interval 0:00:30
2021-05-29 10:03:23 WARNING (MainThread) [homeassistant.components.sensor] Updating command_line sensor took longer than the scheduled update interval 0:00:03
2021-05-29 10:03:29 WARNING (MainThread) [homeassistant.components.sensor] Updating command_line sensor took longer than the scheduled update interval 0:00:03
2021-05-29 10:03:29 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Timeout sending notification to https://mobile-apps.home-assistant.io/api/sendPushNotification
2021-05-29 10:03:35 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 56, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 74, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 135, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 131, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/websocket_api/http.py", line 43, in get
return await WebSocketHandler(request.app["hass"], request).async_handle()
File "/usr/src/homeassistant/homeassistant/components/websocket_api/http.py", line 141, in async_handle
await wsock.prepare(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_ws.py", line 135, in prepare
payload_writer = await super().prepare(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_response.py", line 378, in prepare
return await self._start(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_response.py", line 386, in _start
await self._write_headers()
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_response.py", line 458, in _write_headers
await writer.write_headers(status_line, self._headers)
File "/usr/local/lib/python3.8/site-packages/aiohttp/http_writer.py", line 119, in write_headers
self._write(buf)
File "/usr/local/lib/python3.8/site-packages/aiohttp/http_writer.py", line 67, in _write
raise ConnectionResetError("Cannot write to closing transport")
ConnectionResetError: Cannot write to closing transport
2021-05-29 10:03:59 WARNING (MainThread) [homeassistant.components.sensor] Updating command_line sensor took longer than the scheduled update interval 0:00:03
2021-05-29 10:04:01 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Timeout sending notification to https://mobile-apps.home-assistant.io/api/sendPushNotification
2021-05-29 10:04:05 WARNING (MainThread) [homeassistant.components.sensor] Updating command_line sensor took longer than the scheduled update interval 0:00:03
2021-05-29 10:04:12 WARNING (MainThread) [homeassistant.components.automation.input_amp_limit] input amp limit: Already running
2021-05-29 10:04:19 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ping binary_sensor took longer than the scheduled update interval 0:00:30
2021-05-29 10:04:37 WARNING (MainThread) [homeassistant.components.sensor] Updating command_line sensor took longer than the scheduled update interval 0:00:03
2021-05-29 10:04:43 WARNING (MainThread) [homeassistant.components.sensor] Updating command_line sensor took longer than the scheduled update interval 0:00:03
2021-05-29 10:05:11 WARNING (MainThread) [homeassistant.components.sensor] Updating command_line sensor took longer than the scheduled update interval 0:00:03
2021-05-29 10:15:18 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=44 from 2021-05-28 17:39:46)
2021-05-29 10:15:31 WARNING (MainThread) [homeassistant.setup] Setup of utility_meter is taking over 10 seconds.
2021-05-29 10:16:57 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform filter is taking over 10 seconds.
2021-05-29 10:21:02 WARNING (MainThread) [homeassistant.components.sensor] Updating command_line sensor took longer than the scheduled update interval 0:00:03
2021-05-29 10:21:02 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating workday binary_sensor took longer than the scheduled update interval 0:00:30
2021-05-29 10:21:02 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ping binary_sensor took longer than the scheduled update interval 0:00:30
2021-05-29 10:21:02 WARNING (MainThread) [homeassistant.components.sensor] Updating tado sensor took longer than the scheduled update interval 0:00:30
2021-05-29 10:21:19 WARNING (MainThread) [homeassistant.components.sensor] Updating command_line sensor took longer than the scheduled update interval 0:00:03
2021-05-29 10:21:20 ERROR (MainThread) [aiohttp.server] Error handling request
self._write(buf)
