Feature request for sensibo sky and ambi climate
hi
Could you please add off mode in sensibo sky? the thermostat for sensibo sky is complicated to switch off.
For ambi climate component, i cannot switch the mode and no direct button to switch it off. please add the feature
plzzzzzzzz add it.
Have you read this:
If you want a “Quick Switch” to turn your AC On / Off, you can do that using the following Switch Template :
switch:
    switches:
      ac:
        friendly_name: "AC"
        value_template: "{{ is_state('climate.ac', 'cool') or is_state('climate.ac', 'heat') or is_state('climate.ac', 'dry') or is_state('climate.ac', 'heat')}}"
        turn_on:
          service: climate.turn_on
            entity_id: climate.ac
        turn_off:
          service: climate.turn_off
Yes, but if thermostat card can have off mode will be much better to control.
