Hi guys,
My HA instance, (like most of you), has expanded out with great gobs of devices and entities. That combined with the 130 entry limit, (or whatever that magic number is). Sharing devices and entities with HomeKit has become problematic.
I know that there’s the *glob
style inclusion/exclusion in the config file. I’ve taken to generating my own yaml file based on JQ
queries and my own bash scripts.
However, what would be nice is if the sharing of devices/entities is based on those that are assigned to an area.
So, a good example is my current config for my front door, (with a lot of entities removed for brevity):
- name: HASS West External
ip_address: x.x.x.x
port: 24000
filter:
include_entity_globs:
- binary_sensor.*west_external*
- sensor.*west_external*
- light.*west_external*
- media_player.*west_external*
- remote.*west_external*
- binary_sensor.front_door_camera_*
- camera.front_door_camera_*
exclude_entities:
- camera.front_door_camera_mainstream
- binary_sensor.front_door_camera_tamper_detection
- binary_sensor.front_door_camera_storage_failure
- button.front_door_camera_set_system_date_and_time
- sensor.ble_rssi_west_external_environment
- sensor.ble_voltage_west_external_environment
- sensor.front_door_camera_last_clock_synchronization
- sensor.front_door_camera_last_reboot
- sensor.front_door_camera_last_reset
- sensor.front_door_camera_processor_usage
- sensor.west_external_environment_sensor_signal_strength
- sensor.west_external_environment_sensor_voltage
include_entities:
- binary_sensor.control_pir_as_binary_sensor
- binary_sensor.night_detect_as_binary_sensor
- binary_sensor.postponed_due_to_moisture_2
- binary_sensor.postponed_due_to_moisture_3
- light.control_pir
- light.night_detect
- light.west_external_light
- number.countdown_minutes_2
- number.countdown_minutes_3
- sensor.irrigation_status_2
- sensor.irrigation_status_3
- sensor.soil_moisture_2
- sensor.soil_moisture_3
- sensor.soil_temperature_2
- sensor.soil_temperature_3
- sensor.water_spent_2
- sensor.water_spent_3
As you would know, sometimes you don’t get a say in what unique_id an entity has and/or it’s unmanageable to make changes on a gazillion entries.
So, a simpler way would be something like this:
ip_address: x.x.x.x
port: 24000
filter:
include_areas:
- west_external
- front_door
exclude_entities:
Better still, if there was a way of also excluding entities within an area:
ip_address: x.x.x.x
port: 24000
filter:
include_areas:
- west_external
- front_door
exclude_areas:
- west_external_exclude
Or maybe if there was a generic tag
feature that you could set on entities:
ip_address: x.x.x.x
port: 24000
filter:
include_areas:
- west_external
- front_door
exclude_tags:
- exclude_from_homekit
Then the whole assignment of devices and entities could be managed from areas rather than having them in configs and/or from the UI.
