norien
(Norien)
October 28, 2017, 5:38pm
1
I have started using groups inside groups to clean up my UI and to shorten some of my larger groups such as device status. I would really love to be able to set the icon based off status of whats inside that group!
for example:
group:
device_status:
control: hidden
entities:
- automation.notify_if_device_goes_offline
- group.device_status_cameras
- sensor.roomba
- sensor.echo_dot
- sensor.google_home
- sensor.wemo_link
- sensor.philips_hue_hub
- sensor.chromecast_backyard
- sensor.chromecast_kitchen
- sensor.raspberry_pi
- sensor.raspberry_pi_zero
- sensor.tracker_doorbell
- sensor.bedroom_led_strip
- sensor.room_masterbed
- sensor.room_laundry_room_sensor
device_status_cameras:
control: hidden
icon_template: "{% if states.group.device_status_cameras.state == 'online' %} mdi:camera {% else %} mdi:alert-outline {% endif %}"
entities:
- sensor.dlink_camera
- sensor.driveway_camera
lpt2007
(lpt2007)
March 23, 2018, 4:43pm
3
Can I use icon template inside group? How?
+1 for this! Would be great for a weather view having a dynamic icon based on current conditions…
RonJ103
(Jeremy Scuteri)
June 4, 2018, 1:32am
5
I would also like to be able to do this.
Yup, need this too as i have light groups inside groups and right now the icon stays desperately off!
use this:
homeassistant:
customize:
group.personal:
templates:
icon: >
if (entities['sensor.home_badge'].state === '0') return 'mdi:account-off';
if (entities['sensor.home_badge'].state > '1') return 'mdi:account-multiple-check';
return 'mdi:account';
of course this is based on another entities state, but you could use any entity.
btw this is a view: true group, so even the tab icons are changing.
Thanks for that Marius. Do you know if this can be used with group entities for conditionals as follows:
homeassistant:
customize:
group.garden_light:
templates:
icon: >
if (entities['group.garden_light'].state === 'off') return 'mdi:lightbulb';
if (entities['group.garden_light'].state === 'on') return 'mdi:lightbulb-outline';
If yes, this would solve my issue! Unable to test this as we speak unfortunately!
must be yes.
this works in my setting dev-tools:
{% if is_state('group.family', 'off') %} 'mdi:lightbulb'
{% else %} 'mdi:lightbulb-outline'
{% endif %}
if you’d want to prevent it from failing in case of unknown, add another safeguard:
{% elif is_state('group.family', 'on') %} 'mdi:lightbulb-outline'
{% else %} 'mdi:help'
{% endif %}
or in the other syntax:
templates:
icon: >
return 'mdi:help';
Thanks a lot. Great on you.
I was weirded out by the syntax you wrote. Is that an old version/pre-jinja2?
?not sure what you mean?
the {% %} variant is jinja which you can try in the dev-tools in Hassio, and is computed server side. The other syntax is used in the custom-ui and tiles custom cards for example, javascript, which is computed in browser, client side.
again see the link to @andrey 's templating documentation .
Wow, thanks for that. I did not realise you could use special templating for the custom_ui. Just getting the hang of Jinja. I’ll stick to that for a litte while!
Ok, the custom-ui templating works well as follows:
group.light:
templates:
icon: >
if (entities['group.light'].state === 'off') return 'mdi:lightbulb';
if (entities['group.light'].state === 'on') return 'mdi:lightbulb-on';
return 'mdi:help';
Could not get the regular templating to work and no icon would be displayed.
Thanks Marius!
This does throw errors when entities are not created on startup, for example due to lack of connection. Tried to use on door/window sensors but Hass would fail to load!
I know this is old but I voted on this one too. Unless I’m missing something, none of the replies are a solution to the OP request.
I seem to only be able to specify an icon (I choose lightbulb for each group) but no way to change it to an “lightbulb-on” for each group icon when the state of that group is on. See below for a visual and an example of group code.
group:
daily_outside_lights:
name: "Daily Outside Lights"
icon: mdi:lightbulb
entities:
- light.somelight1
- light.somelight2
- light.somelight3
- light.somelight4
- light.somelight5
christmas_lights:
icon: mdi:lightbulb
entities:
- light.somelight6
- light.somelight7
- light.somelight8
christmas_candles:
icon: mdi:lightbulb
entities:
- light.candle1
- light.candle2
- light.candle3
- light.candle4
- light.candle5
- light.candle6
- light.candle7
- light.candle8
