Feature Request: LG webOS expose and configure Device Connection Settings
I’ve read and searched but can’t see if this is already available or if indeed it is possible? So is it possible to change the SIMPLINK settings through this integration? I can change the sound mode to external_arc when I want to use Surround Sound in my setup. This turns both SIMPLINK and Auto Power Sync on. When I return to tv_speaker SIMPLINK and Auto Power Sync remain on, is there a way I can turn them off within an automation? I don’t need the AMP on for most of the TV watching. I was thinking of adding a step to the automation to turn the AMP off, but when I did a simple test, because of the power sync both AMP and TV turned off.
History: I’m on the journey to remove reliance on subscription TV services. Until now I’ve played almost everything through my Yamaha AMP and the TV is almost just the display. However, on my current path the TV will have a more active role.
