[Feature Request] Switch individual blueprint fields types to a template type
I love using community blueprints! However I find that there is some friction when I want to intermix the pre-configured inputs along with template yaml inputs.
The Problem - When a blueprint has a field such as a timestamp, I sometimes want to use a template to input a value rather than hard coding a value. Currently the only way to do this is to switch the whole blueprint over to edit the yaml and insert the template into the variable I want. This is frustrating because often I only have one value where I want to use a template and the remaining fields I want to use the per-configured field types and I don’t want to have to set the yaml for those fields because the GUI is just easier.
What I want - I wish there was a way to specify that an individual field can be set as a template value without leaving the GUI.
Possible solution - I mocked up what the interface might look like below. Each field would have a template button on the right side as indicated by the open and close curly braces ‘{ }’. When clicked, the datetime input field would toggle over to a template input field type.
Hello mhlas7,
Even though it’s not in the Feature Request category (which is good, this doesn’t belong there…)
This appears to be an attempt at a Frontend Related Feature Request as it is asking for changes to Frontend Menus, Dashboards, or Sections.
These Feature Requests are handled in a different system, and will not be seen by the right people here.
Please add your Feature Request into GitHub here:
home-assistant/frontend Other Feature Requests · Discussions · GitHub.
See more info about Feature Requests HERE
Thanks! I have submitted a ticket in GitHub. Feel free to delete this thread.
