Feature Request Guidelines 📔
What is a Feature Request
Guidelines from the Blog: Go to this HA Blog Link to better understand what role Feature Requests play in the development of Home Assistant and how you can help.
Everything goes here: home-assistant · Discussions · GitHub
See this post for details...
Add External USB Drive support for Home Assistant Green
Mesh multiple HA servers together
Zha tuya touch dimmer switch
Support of Aeotec Zigbee Pico (Duo) Switch requested
ESPHome component master HomeAssistant (No MQTT, No Helpers)
Orvibo AllOne Pro
User administration
Voice platform with POE power option
Integration Magnetar UDP800 & UDP900
Display sensor as iOS widget
Add support for LAN Motorcomm YT6801
Daikin Onecta COP calculation
Automation Visual Editor - Further Enhancements
Blossom-ic or Hera+ connect
Remootio Integration
Block/blacklist a Zigbee device from joining ZHA?
Shelly Gen3 Support (e.g. PM1 Mini Gen3)
Create Blueprint with variable triggers?
Monitoring NVMe drive health in a Home Assistant Yellow
Satel - Unique ID
Termostato Plick NEVE X
Statistics graph legend
Styling the toolbar
Light-O-Rama Integration
Compatibility Govee H6176 LED Strip
Energy Dashboard, show grid import on Elecricity bars
Ollama Addon: Running SLMs Locally on the Same Box and Not Just Remotely
Disable backups by default
Hints on how to add color support for Philips Hue and LEDVANCE lights in Netatmo API integration
Automate Clean Build Files and Install
Turn off spell check in text fields
Automations: Sort by Last Modified
Add filters and grouping bar to Developer Tools States section
Iotty smart switch and plugs
General optimistic support
Rework Zone
Show power on energy dashboard
Please hep develop TCP/ IP integration for a lighting brand
Templates in conditional cards
LiveWire S2 MotorBike
Airthings View Plus - web integration doesn't present radon or pressure sensors
Sensibo Sky power consumption attribute?
Mobile - Swipeable views
Long time Dashboard
Integration Sencor Weather Station
New Integration
Prevent number entities (sliders) from moving accidentally when scrolling through entities
Reordering Floors, Categories, Etc
Performance Mode: Disable UI Animations Per Device
Add SolarAssistant integration
Add a secondary category menu to the "Add Integration" page
Add a color coding option to Home Assistant Automation/Script/Scene builder UI
Connectlife integration
Extend Tuya - history consumption - complete and often missing
Mesa drivers addon for haos
Scent suggestion integration.... perfect perfume for every day!
Ridwell featured category sensor
Add markers in history graphs
Google Contacts Integration
ESPHome "Validate All" option
Green Button Connect - Ontario
Inkbird: add support for IBS-TH3 sensor
Expose /dev entries on ODROID for Rockchip ffmpeg acceleration
ZHA Integration Support for Humidity for RSH-Hs06
Group by label in entities and automations, more?
Notifications for Android TV / Fire TV: Text color mostly
MelCloud --- Binary sensor for error state Air to Water
Disable NAS storage checking
Enable SSHFS as protocol for Network Storage
Extend posibilities for cards
Honda plus integration
Cync thermostat or cameras
Add-ons container cpus limit settings
Device_class missing: Fuel, Diesel, petrol
Ability to hide configuration options in Blueprints
Add support for ECOPOINT EV Wall Charger
Slicer to turn of solar panel energy production
Garnet SeeLevel 2 tank sensor data
Schedule trigger & selector
Robinhood Crypto Integration
Versions drop down in the update dialog
Google Nest Fan Control
Home Assistant Add-on: RPC Shutdown
Add note about "legacy" format to be used for OTA update from access point WebGUI
Tuya Integration not providing battery percentage for Radiator valve
Upsert service for Google tasks
Media player - now_playing_url entity
Ecoflow integration
Use variable to set color 2
Energy Dashboard: adding new devices for energy consumption tracking automatically
Add option to contribute voice commands to Mozilla Voice
Search YouTube for videos
5th colums on ultrawidescreen
Add password protection to automated OS backups
Ability to group toggles
Color_temp_kelvin should be adjustable via UI in the automation editor
Elmax alarm global command
Leviton Decora Bluetooth Dimmer Integration
Helper as a template
A Simple Extension to the Alert Integration
Yamaha audio DSP MTX 3/5 & MRX
Feature request / feedback. Script / Automation debugger improvements
Inconsistent margins and more across the entire app
People group
Add high pass filter option
Home Assistant Strategy stands justified
Add the ability to move the lovelace page navigation bar from the top of the screen to the bottom
Add option to change device_type "cover" to device_type "valve"
Not_from and not_to supports in visual mode
Provide a count of devices, entities, helpers in the search bar
Settings Location
Logs that show where error occurs (incl. cards and helpers)
Tuya unsupported temp & humid sensor
Tado X integration
GUI: wider dropdowns for better visibility of options
Enhanced Service Call Descriptions with Secondary Information
Control lamp card
Home and Vehicle Maintenance Integration
HA and Siemens Logo - Switch vs. Click - bidir. Synchronization
Internal URL: WIFI & POE Ethernet
Tibber Integration - Entity Total Cost of the Month
RFCOM feature request
MyUplink Thermostat card
Blueprint for packages
Suggestion for Improving HDMI-CEC Integration
New Integration request - AENO Smart Heater
Need a Group UI version of the Devices UI
Energy card with Power on Now button or Power-flow-card-plus merger with the energy-flow-card-plus
Change Category Divider Background
Add Input Sensor information to Threshold Sensor Helper Options
Primagaz integration request
ESPHome Disable WiFi in order to save power
Time conditions for conditional card / visibility
Some HACS plugins that I feel should be added to Integrations
Comments/Description in scripts dialog box
Feature Request: local USB Backups – The Most Basic Missing Function EVER! 💾
TFIAC integration issue
Show duration of trends
Sync the x-axis (time) Zoom when multiple entities are shown
Low performance of HA Backup
Make `entity-filter` badges as functional as `entity` badges
Generic Thermostat add window_sensor support
Boundary Plus / Invisible Fence Integration
2FA in QNAP NAS integration
ZHA: Tilt on (Aqara) vibration sensor
Media folder content - select all option missing
Touchstone Smart Fireplace
Advanced energy analytics with drill-down capabilities for sustainability and efficiency optimization
ADD function to set new Max Flow Temperature
Nimley Touch Pro via ZA
Hope to add switch binding function
ISBG + SpamAssassin
Add more space to the pool, or secondary pools
Can you add the Waterkotte Heatpumps please to the system
Customise Date in Energy Dashboard
Add Sync feature to graph card to synchronize zooming and panning on multiple values
Dynamic Column Count in Lovelace Grid Card Based on Screen Width
Way to request new ZHA device handlers without involving Microsoft
Request to add temperature control buttons in horizontal view - THERMOSTAT CARD
Add support for copy more than 1 card to the clipboard
Integration for amperfied Wallboxes
Default view for Developer Tools > States
Frontend: Add "No Label" "No category" "No area" Filter for entities, devices, scripts etc
UX for setup with screen on device
Themes for tile card and other cards
Remove 'Filter' Options with one click (instead of three)
Make sections collapsable/expandable
Turn Off Default 'Group by Category' in Automations, Scenes, Scripts
Edit titles of items in sidebar
Refresh Button after updating or installing a card from HACs
History/Statistic graph card: option to stack the lines or bars
Brightness presets (buttons)
Fan entities need to support number speeds and allow set_speed calls instead of percent
Add a column stating the input sensor to (at least) the list of helpers
Set custom icons for select-options in Tile feature to display feature with style=icon
Drag on an area to copy out its YAML to the clipboard
Floating or foldable history graph
Sections: Allow Websites as Background
2 switching options for all graph diagrams
Open-Meteo add additional parameters
[Feature Request] Switch individual blueprint fields types to a template type
Escape in Lovelace editing mode to exit editing mode
Input source dropdown for Media Player Tile card
Simple UI to create temperature entity from climate attribute
Panasonic Evervolt Integration
Free configuration of onedrive integration
Play icon for selected media files
Removing formatting in an LLM response
Area Manager – Drag-and-Drop for Assigning Entities, Devices & Areas
Templated Dashboard view with drag&drop entities
Logbook Card - more filtering options
Mspa Osla Integration
Allow picture entity as dashboard background
HACS Pending Restart Detection
Auping connect integration request
ZHA sensors for Sunflowers are a shame
Request for Independent Code and Preview Views
Show statistics as data table
Fyta - min/max thresholds
Todo-list card: more options
Picture Elements SVG Interactions
Feature request: show price on individual usage on energy monitor
Android Widgets - Click on the widget to open the graph
Thermal energy monitoring
Pin items in tables
Can we add visual support (UI and Traces) for the already supported top-level automation variables?
Enable the use of html div tags right in ha with a separate CSS file in the www folder for styling
Tap to mark, hold to edit entries in the shopping-list
A dashboard that allows the user to select favorites
Music Assistant - Fetch Album Art from LastFM
Cursor movement & zoom in History graph card (and history view in general)
Feature Request for the Tile Card light color bar anda dd a few buttons
For the humans
Customization of Log-in page
Card - Enable to save configuration/yaml without exiting the editor
Simple MQTT Chat
1x1 Section Tiles
A logical floor plan
New Card - Selectable Entities
Button to collapse / expand all
Notifications for Android TV Integration additional parameters request
The Backup 'repair' should have an option to retry
Status Window - Areas
Gree Climate distinct sensors
ANTHBOT Support
Add date (optional) to new clock card
Tile card feature for remote
Statistics Graph Card: Please Sort floating legend by value!
Add lock state feature in cards
Make automation descriptions visible (show/hide optionally)
Lovelace card for Music Assistant Integration
List group members in the Related popup
MeshCentral addon request
AVM Fritz!BoxTools: add VPN WG control (on/off)
2 million homes strong - State of the Open Home 2025
Request for extending TP-Link functionality
Allow duplication of Views across Dashboards
Zones Map expand the added zones so easier to view and edit please
Add possibility to use templates in lovelace
Update/Notification Indicator in Browser Tab
Request for Surplife Integration
Tile card for input_text suports feature_postion: inline
BTicino Easykit wifi
Sending webhooks as an action, configurable via the UI
Toro Tempus irrigation system Integration
Integration request OSC (open sound control)
Integrations creating entity ID's without a prefix
[OpenUV] Add time for protection window start and stop
Expand the "related" function when looking at an entity so it also shows which helpers use it
Add an extra row to support mushroom light card
Request: support for hamlib
Conditional Styling and Display Logic of card elements in GUI without yaml
Left/right swipe between dashboards (iOS)
"Are you sure" for the cancel button when editing cards
Label or indicator to automation off identify
VL53L1X distance sensor support
Sections dashboard, make possible to have multiple rows of badges
Query ZHA supported device
Devices per endpoint when using Asterisk
Template macro as helper
A Map of Devices
xBloom Original & xBloom Studio Support
Improve logging for http component/documentation of "Can only log in from the local network"
Blink Battery Level Integration
Vanderbilt SPC - add ENTRY/EXIT2 zone type same as ENTRY/EXIT (DOOR)
Label overview page like the areas overview pages
Energy Dashboard: Allow more data to be shown when zooming in
Diivo integration
Google WiFi Configuration with Unique IDs?
Need a option to Integrate realme link devices
Generic hygrostat: support fan speed levels
