Feature Request: Tailscale oAuth instead of API key
Currently, you have to reconfigure the Tailscale Integration every 90 days because of the API Key expiring.
They also offer oAuth for API Access, which doesn’t expire.
Could this be added (as second option) to the Tailscale Integration?
Thanks in advance
Aaron
Or at least be able to re-enter the new key
This would be a compromise but not the ideal solution because you would still need to generate and enter a key every 90 days…
We need OAuth if we want to really make it maintenance-free as it should be…
Bump. This is absolutely needed for this integration to frankly even be worth using.
