kasper1
(Kasper)
1
I am trying to change an input_number within an Automation.
When I define an absolute number, everything runs smoothly:
However, when I try to use another input_number, it does not work:
I have tried the following combinations in the “Service data” field after reading through some documentation and past forum topics:
value: {{input_number.temperature_day}}
value: '{{input_number.temperature_day}}'
value: states(input_number.temperature_day)
value: {{states('input_number.temperature_day')}}
value: '{{states('input_number.temperature_day')}}'
But nothing works. Any hints how to proceed?
m0wlheld
(Christoph Dahlen)
2
value: '{{states('input_number.temperature_day') | float }}'
should do.
kasper1
(Kasper)
3
Thank you for the fast response. Your proposed solution does not work for me: the value of input_number.temperature_current does not change.
Screenshot:
I copied the errors in the log:
Logger: homeassistant.components.automation.schedule_set_temperature
Source: helpers/script.py:1147
Integration: Automation (documentation, issues)
First occurred: 11:24:17 (1 occurrences)
Last logged: 11:24:17
Determine Set Temperature: Error executing script. Invalid data for call_service at pos 1: expected float for dictionary value @ data[‘value’]
Source: components/automation/init.py:408
Error while executing automation automation.schedule_set_temperature: expected float for dictionary value @ data[‘value’]
m0wlheld
(Christoph Dahlen)
4
You need to mix double quotes with single quotes (or use double-single-quotes), otherwise you break the YaML
value: "{{ states('input_number.temperature_day') | float }}"
or
value: '{{ states(''input_number.temperature_day'') | float }}'
kasper1
(Kasper)
5
Thanks, your suggestion to use double quotes fixed it! Now it behaves like expected.
