I have tried to use the new Feedreader component in 0.18.2 but when I used a URL which is a RSS 2.0 feed, HASS will not start (ie it breaks HASS). When I remove it from the config.yaml, HASS works as expected.
I could use some Feedreader help too. I used the URL from the Feedreader component section just to test it, and I get an error during the setup of the Feedreader setup, KeyError: ‘published_parsed’.
Hi folks, I’m no expert of feeds so I’m not sure if I’ll be able to fix/help with this. What I did to develop the component was just to wrap some HA code around feedparser Python library, and from what I understand from the docs, RSS 2.0 should also be supported too.
@phileep can you test the latest available version of feedparser is used from your HA?
@Marauder2, @vswraith can you provide some more context? i.e. paste the stack trace into some pastebin service?
Apparently there’s the need to add some more data validation in the component, we can’t assume that every entry object has published_parsed data available. I’ll come up with a fix soon, thanks for reporting this
Yes, not every component has a frontend counterpart, and feedreader, at least in my initial idea, is only supposed to work in the background and fetch data to be used to trigger automation actions, or by custom components. Out of curiosity, what would you like to see in the frontend?
Sorry, I’m a real noob on the frontend side, can’t help much here, and I don’t have the need for anything feedreader related there so I’m afraid I will never follow up on this. But sounds like a good idea to me
