Picked up a 3 pack from Costco and unfortunately these have new firmware so I cannot flash with tuya-convert. I opened one and saw that its a TYWE1S and it does have 4 holes exposed. I have not been able to get it to flash using espflasher. Maybe because gpio0 needs to be grounded? Looking at a diagram, it seems to be under the module.
Would be be awesome to know if someone has been able to figure these switches out. I dont know how I feel about using the tuya component.
Yes, you need access to gpio0 and it’s under the TYWE1S. At least two ways to access it are described in the following thread (plus several other things you need to know in order to control these dimmer switches):
Short of having to flash the devices - is there any way to use the feit dimmers with HA? They seem to be quite prevalent lately.
Tuya integration or the custom local tuya integration.
So connect them to Tuya instead of the FEIT app and then use Tuya in HA?
