Feit Electric SD06 3-Way Switch - Can HA Dim this Switch?
Coscto (US) sells a pair of Feit Electric SD06 3-Way Switches for $20 so I picked some up. I was able to add them using Tuya Smartlife app, then proceeded to get the local key from the Tuya IOT site. I was then able to gain local control of the switch via HA.
However… The SD06 is a dimming switch. I can see the switch attributes when I view the device details in Tuya IOT. However, I don’t see the brightness state when I view the switch in Developer Tools, State. I only see if it’s off or on.
So… I have no idea if setting the brightness via HA is an option or not. I fiddled around with calling on the service in Developer Tools, Services, but so far no joy.
Does anyone know if the brightness can be set via HA for this switch?
