Update:
I have completed this quest. In short, it is now possible to OTA flash this device with OpenBK7231, which has direct support for HomeAssistant via MQTT.
I did have to open one of the devices, dump the firmware and upload it to the Tuya CloudCutter project - so now you don’t have to. The fine folks over there created a new profile (within minutes!) and now it’s possible to flash these device 100% OTA.
As a side benefit, the WiFi performance of these LED strips is drastically better with the OpenBK firmware. The only negative is that the BLE remote that comes with the LED strip no longer works - but all of mine were sitting in a ziplock bag in an IoT storage container anyway - so I don’t care.
I have posted all of the details on the Elektroda forum here.
Shout out to everyone contributing to Tuya Cloudcutter, OpenBK7231, and OpenBekenIoT for their fine work!
Feel free to ping me if you have any questions!
Original post:
It seems that a lot of work has been done over the past year to jailbreak some of the more recent Tuya devices that switched from ESP chips to Beken 7231 chips. The Tuya Cloud integration (obviously) requires cloud access, and Tuya Local is not ideal in a number of ways - for example, if you reset the device, you have to obtain a new set of keys from Tuya cloud. Ooof.
There is a Reddit thread that includes a teardown of the subject LED strip controller - it is definitely a BK7231T chip.
There are at least 2 separate GitHub projects (and associated projects) with custom firmware for these chips, and a Github project with an implementation of a firmware exploit that allows OTA firmware loading:
There is libretuya + esphome which provides for ESP-compatible firmware that can be flashed onto this family of chips.
There is another project called OpenBK7231 with some support for HA & MQTT. Here is an example project with a FEIT RGBCW bulb using this approach.
Finally, there is a project called Tuya Cloudcutter that jailbreaks a number of Tuya devices over the air and allows for OTA firmware loading.
Given all of these ingredients, it seems like flashing ESPhome or an MQTT implementation onto this range of Tuya devices is within reach.
Before I start trying to break stuff, my question is whether anyone here has successfully jailbroken one of these particular LED strips (or any FEIT BK7231-based accessory) and if so, can you share what you learned?
Utimately, if this is feasible, it could be a much better future path for HA users currently on Tuya Cloud or Tuya Local, and a combination of these project could even make for a pretty slick HACS package that could jailbreak, flash and add jailbroken Tuya devices to HA.
