Fellow Stagg EKG Pro Kettle (Espressif) integration
I bought the Fellow Stagg EKG Pro Kettle. It includes Wifi connectivity. I see the Kettle uses a Espressif chip. I was wondering if there is a way to connect & integrate it into Hassio?
That sounds like you can install esphome on it. Still worth to figure out if others were successful in that endeavor and if all sensor/actors connected to the esp chip are working/supported.
I guess it’s not a highly adopted product. So it may take a while before this will be figured out.
Looks like someone made some good progress (but not fully HA integrated) here: GitHub - tlyakhov/fellow-stagg-ekg-plus: WiFi & Google Assistant Bridge for Fellow Stagg EKG+ electric kettle
He thank you for sharing, but I think this is about the plus version (from 4 years ago), not the Pro (latest) version. The Pro version also doesn’t have BLE connectivity, only Wifi.
Would be nice fore me too, but sadly dont know how to Programm it
So, a kettle supports Bloetooth and that’s the way you connect it to the Wi-Fi. Unfortunately, however, it looks like, at least for now, the controls are very limited.
There is a characteristic exposed, 2291c4b5-5d7f-4477-a88b-b266edb97142, which apparently holds the settings. Characteristic is marked as writeable, so I assume it should be possible to modify the settings remotely. It looks something like that: f7170080c880c0800000060c001e01003b.
For example, the currently set temperature is held in the byte [4], where every “tick” is half of the degree Celsius, so c8 = 200 “ticks” = 100 degrees, or 50 = 80 = 40 degrees. The time to hold the temperature is held in the byte [13] with plain value in minutes (0, 15, etc). There is also a “request/response counter”, byte [10], mentioned in the EKG+ reverse engineering thread. The last byte [16] appears to be the checksum.
I couldn’t find the characteristic holding the current state of the kettle, unfortunately, so no current temperature or state (like hold/set or whenever a kettle is on the stand).
While it could be fun to add it to Home Assistant, I don’t think it has any practical value so far. Let’s see, maybe Fellow will add more functionality to it.
Following this thread. I picked up a Pro Studio and curious if it can integrate as well.
Hi! I just finished an integration with the Bluetooth kettle, I hope this helps! GitHub - levi/stagg-ekg-plus-ha: Stagg EKG+ Home Assistant Integration
He! You got me excited here! Sadly it doesnt seem to work. I used the ble scanner and got the MAC address and name confirmed. I can add it as a device into my home assistant OS but no luck. I assume my Fellow Stagg EKG Pro works differently. Any ideas?
@levi2 I checked my ble logs, it seems the UUIDs are different than from the plus version:
SERVICE_UUID: B4DF5A1C-3F6B-F4BF-EA4A-82030490-1A02
CHAR_UUIDs (multiple available):
  • B4DF5A1C-3F6B-F4BF-EA4A-820350FF1A02
  • B4DF5A1C-3F6B-F4BF-EA4A-820351FF1A02
  • B4DF5A1C-3F6B-F4BF-EA4A-820352FF1A02
  • B4DF5A1C-3F6B-F4BF-EA4A-820353FF1A02
  • B4DF5A1C-3F6B-F4BF-EA4A-820354FF1A02
@levi2 how did you get the commands? What did you use to read it, Wireshark? I believe the pro version uses different commands. I managed to establish a connection and getting some data through, however incorrect.
Hey Murp, I finally joined the community just to respond to this. I also have a Pro and am trying to get the commands figured out so if you make any headway, let me know and I’ll do the same!
See my other post of today BLE reverse engineering a Fellow Stagg EKG Pro kettle - #2 by Murp
The only way reach the chip is by physically access it, which damages the label on the bottom. I tried to fetch every command by using ble sniffer. It’s seems impossible to turn it on and off. Other things like changing the temp or changing settings worked fine. However turning it on and off were primary needs for my use-case.
Hey! Although I probably won’t use it much, I really wanted to integrate my Stagg EKG Pro with Home Assistant. If something can be connected, it should be, right?
I found through this repository (GitHub - tomtastic/stagg-ekg-pro: Python for interacting with the Fellow Stagg EKG Pro Electric Kettle) that communicating with the EKG Pro is really easy (and insecure).
So I vibed-coded a HACS integration. Obviously use it at your own risk, but it should work – so have fun!
GitHub - fabiankirchen/staggassistant: A custom component for Home Assistant to control the Fellow Stagg EKG Pro over WiFi.
I learned the kettle supports CLI over wifi. Based on this I build a HACS addon. I’m still testing but will share when I feel it’s ready.
First, THANK YOU for putting the work to do this. Second, this is a GREAT integration. It is fast, sleek, and does exactly what I need it to, especially wit real time reporting of the temp, and the ability to turn it on an off remotely.
Third, and very importantly, I had a horrible day at work today, so I decided to come home and track down that mystery IP address. I figured out it was my EKG, and THEN I found out I could connect it to home assistant, and that really made my night better. So thank you!
now, if only the kettle had a way of sensing the water level when in was more than empty. lol
Here you go: GitHub - bramboe/stagg-ekg-plus-ha: Stagg EKG Pro Home Assistant Integration it’s quite complete
Just installed. It looks great! Thank you!
