You can see an example here of how it comes out…
But here is the data for the sensor state…
channel:
channel_id: '17577'
field1: Temperature
field2: Humidity
field3: Light
field4: Voltage
field5: WIFI RSSI
field6: GSM RSSI
field7: EXT1 Temperature
field8: EXT2 Temperature
field9: RS485 Temperature
field10: RS485 Humidity
elevation: null
created_at: '2020-08-19T11:41:18Z'
updated_at: '2020-12-21T03:45:26Z'
metadata: >-
{"fn_th":60,"fn_light":60,"fn_ext_t":60,"fn_battery":10800,"fn_485_th":0,"fn_485_sth":0,"fn_dp":300,"net_mode":0,"no_net_fn":1,"cg_data_led":1,"wifi_mode":1,"thres_acc_min":0}
tags: null
public_flag: 'false'
url: null
description: null
usage: '15518504'
device_id: xxx
status: >-
XXXX
status_date: '1612741275'
last_ip: xxxx
channel_icon: null
product_id: ubibot-ws1p
plan_code: ubibot_free
plan_start: '2020-08-19T11:41:18Z'
plan_end: null
bill_start: '2021-01-16T11:41:18Z'
bill_end: '2021-02-15T11:41:18Z'
traffic_out: '323675'
traffic_in: '7467993'
full_dump: '0'
renew: null
last_values: >-
{"field3":{"value":0,"created_at":"2021-02-07T23:40:21Z","net":"1"},"field1":{"value":10.390633,"created_at":"2021-02-07T23:40:21Z","net":"1"},"field2":{"value":32,"created_at":"2021-02-07T23:40:21Z","net":"1"},"field4":{"value":5,"created_at":"2021-02-07T20:45:53Z"},"field5":{"value":-55,"created_at":"2021-02-07T23:35:24Z"},"field8":{"value":23.4375,"created_at":"2021-02-03T18:38:11Z","net":"0"},"field7":{"value":41.875,"created_at":"2020-12-19T00:42:48Z","net":"0"}}
vconfig: >-
{"field1":{"h":"0","u":"1"},"field2":{"h":"0","u":"3"},"field3":{"h":"0","u":"4"},"field4":{"h":"0","u":"5"},"field5":{"h":"0","u":"6"},"field6":{"h":"0","u":"11"},"field7":{"h":"0","u":"14"},"field8":{"h":"0","u":"14"},"field9":{"h":"0","u":"12"},"field10":{"h":"0","u":"13"}}
sensors_mapping: null
sensors: null
firmware: ws1pro_v1.7.0
cali: null
timezone: null
vpref: null
vpref_from: owner
next_id: '22154'
size_out: '1073741824'
size_storage: '209715200'
full_dump_limit: '3'
